Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Wed Aug 27, 2014 8:19 am Post subject: |
Kevin
I have had good results using a thread file to clean up abused threads.
I'm a little surprised how often I use it, now that I have it.
One other nice thing about them is that they don't care if the threads are left handed. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Wed Aug 27, 2014 10:09 am Post subject: |
If you don't have a thread file, use a triangle jewlers file. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Aug 27, 2014 10:41 am Post subject: |
electronictofu wrote: |
It was just going on really hard and I was afraid of damaging the threads. |
Obvious question but I have to ask it, you are using a right hand thread nut? Sometimes they get mixed up easily. |
BarryL Samba Member
Posted: Fri Aug 29, 2014 12:58 pm Post subject: |
Figured I'd go ahead and do one for you.
Here's a crusty candidate. Granted it doesn't have crossed threads but it is as bad and will be as hard as if it did.
Here's how to chuck it up and insert the blade. You must have already figured all that out if you made your own.
Just pick how many cuts you want and go for it.
I made this one with six cuts.
Gently start it on. I use magnifiers to see if it's going straight.
Then start turning in 1 to 1/2 turn and back up a smidge if it gets tight before going farther but don't be afraid to go for it. You can go dry or use oil. I chose to go dry just to prove a point that it will cut.
After not long I was all the way in.
It was so clean I could back off the nut by hand.
All ready to clean up and go.
If you want I'll send you this nut as it's the same side as you but it's for a '67 as long as that's good for you. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Aug 29, 2014 2:05 pm Post subject: |
paint some muriatic acid on that poor thing before you do your thread repair and it will not clog up so bad. then neutralise with baking soda _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Fri Aug 29, 2014 3:04 pm Post subject: |
You should also be using WD40 or something similar when you're re-cutting the thread. A few turns on, then back it off, clean any swarth off, then a few more turns, back it off, clean swarth....... Over & over until you're done. _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
BarryL Samba Member
Posted: Fri Aug 29, 2014 3:24 pm Post subject: |
True all that ^^^^ guys.
I was just showing the guy with the stripped spindle that he could carefully chase his thread dry or wet if he went slow using the Jypsy die. |
Pacmanfever Samba Member
Posted: Fri Aug 29, 2014 6:28 pm Post subject: |
BarryL wrote: |
I second this, it's a brilliant simple solution. Great pictures and nicely written up too. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Fri Aug 29, 2014 9:19 pm Post subject: |
KombiMadness wrote: |
You should also be using WD40 or something similar when you're re-cutting the thread. A few turns on, then back it off, clean any swarth off, then a few more turns, back it off, clean swarth....... Over & over until you're done. |
I prefer to use actual cutting oil for stuff like this although I have used PB Blaster too.
Great photo tutorial above, thanks for posting that. _________________ How to Post Photos
Posted: Fri Aug 29, 2014 9:55 pm Post subject: |
BarryL wrote: |
Hey Barry, wasn't trying to rain on you.....
It is an excellent tutorial and great close up photos. Also, my bad because I didn't read your post properly and missed you saying you could use oil or go dry.....
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
