Riekert Samba Member
Joined: August 15, 2014 Posts: 34 Location: South Africa
Posted: Sat Aug 16, 2014 4:36 am Post subject: |
So this is what I've been up too...
I've worked with these LED's before and they are really bright.
See pic below:
Threre are 6 of them in this indicator ^^
Here are the little guys:
And a very crude first attempt at the indicator light.
I will do the brake as well as the running light in the same style.
I will just run a resistor to the indicator and running lights to dim thr brightness that bit. but should still be brighter than stock.
I average about 30 LED's per light. So 10 for indicator 10 for brake and 10 for running light.
I might do that the outer ring flashes and the inner just stays on, or something... but will see when I'm done
Lemme know if its ok to post here if if I should rather create a new post!
Thanx! |
Yabbadubbadoo Samba Member
Posted: Sat Aug 16, 2014 6:40 pm Post subject: |
I know the thread topic is about brake lights but the theme is increasing visibility/safety through improving the old lights - so your post is relevant IMO.
Post away! _________________ Sydney, Australia.
66 Type 3 Fastback |
Bobnotch Samba Member
Posted: Sat Aug 16, 2014 8:57 pm Post subject: |
Yabbadubbadoo wrote: |
Post away! |
Yes. Is it 6 or 12 volt? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Aug 16, 2014 9:16 pm Post subject: |
Bobnotch wrote: |
Post away! |
Yes. Is it 6 or 12 volt? |
Do you mean the thread or the Blinker upgrade Reikert posted?
I didn't specify a voltage for the thread. My car is 6v but I'm converting to 12v. If the bulb wattages are the same I expect similar light output since the current would just double in a 6v circuit. I think more heat is generated in a 6v car bulb since the current is higher and incandescent bulbs aren't too efficient at converting the energy to light output so a lot more heat is generated because heat is proportional to the efficiency. I'm pretty sure that's why it's easier to melt your lenses in a 6v car if you put higher wattage globes although I have just a layman's understanding of circuits so that's about the limit of my understanding. I know basic power formulas and a general understanding but an electrical engineer would surely be able to explain why 6v incandescent globes are hot little potatoes that don't generate much light. _________________ Sydney, Australia.
Posted: Sun Aug 17, 2014 7:23 am Post subject: |
Post away! |
Thanx!
Bobnotch wrote: |
And for my exercise i will be using 12v. However it could be done for a 6v system with a bit of work. |
Posted: Sun Aug 17, 2014 7:59 am Post subject: |
Bobnotch wrote: |
Post away! |
I didn't specify a voltage for the thread. My car is 6v but I'm converting to 12v. If the bulb wattages are the same I expect similar light output since the current would just double in a 6v circuit. I think more heat is generated in a 6v car bulb since the current is higher and incandescent bulbs aren't too efficient at converting the energy to light output so a lot more heat is generated because heat is proportional to the efficiency. I'm pretty sure that's why it's easier to melt your lenses in a 6v car if you put higher wattage globes although I have just a layman's understanding of circuits so that's about the limit of my understanding. I know basic power formulas and a general understanding but an electrical engineer would surely be able to explain why 6v incandescent globes are hot little potatoes that don't generate much light. |
I was just wondering if Riekert was building 6 volt or 12 volt leds. It seems that ataraxia had the 6 volt set up pretty much nailed down. I know you mentioned years ago about building different led combos as well.
I'll sit back and watch what happens, as I'm still gathering info on the conversion. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sun Aug 17, 2014 8:05 am Post subject: |
Bobnotch wrote: |
I'll sit back and watch what happens, as I'm still gathering info on the conversion. |
I would love to see some comparable lower cost options for 6 volt. |
Posted: Sun Aug 17, 2014 8:49 am Post subject: |
@Ataraxia - Do you have a link to the 6v version you did?
And I will have all my components necessary for the conversion by next week so will post up the results and costs soon. |
Posted: Sun Aug 17, 2014 9:48 am Post subject: |
Riekert wrote: |
It's all in this thread...just go back a few pages. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Fri Aug 22, 2014 6:50 am Post subject: |
With regard to the idea of flashing the brake lights, as a motorcyclist I think it's a useful attention-getting feature and especially on a vehicle like a motorcycle which does not have a dedicated brake light like cars do with the center high-mounted stop light, it definitely helps to differentiate taillight and brake light for those behind me.
On one of my motorcycles, which has an LED tail & brake light, I used this device:
http://3rdbrakeflasher.com/
Despite the cheesy web site, the product works great - have been using it in the bike for more than three years now with no issues.
Nice thing is you can use it with LED or incandescent bulbs - the flash rate is programmable as are the number of flashes. So on my bike with LED brake light it gives 4 fast flashes then steady light. For an incandescent bulb you could set it for slower flashing which is more suitable for incandescent bulbs.
So you could use this with any LED strip you might install or you could use with the stock brake lights as well.[/url] |
Posted: Fri Aug 22, 2014 7:06 am Post subject: |
sjbartnik wrote: |
So you could use this with any LED strip you might install or you could use with the stock brake lights as well. |
I like that you can program the flash rate and that it's small in size. I'll be looking into something like this once I figure out where to mount my 3rd brake light.
Thanks for the link. |
Eodguy Samba Member
Posted: Wed Aug 27, 2014 10:41 am Post subject: LED Third Brake Light |
I don't remember where I got this from but it works good and is bright and visible, I just ran a wire to the brake light.
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Posted: Tue Sep 02, 2014 5:48 am Post subject: |
I don't think I've read any statistics that identify lack of rear lights as to the reason for rear-end collisions. I've ridding motorcycles for 48 years and have yet hear anyone say they rear ended someone because they didn't have enough lights or they weren't bright enough. There are plenty of vehicles with more than enough lights on the back that get rear-ended every day.
If more or brighter lights make you fell more secure then go for it. _________________ Pearl White 1966 Sedan
Retired US Army - 21 years 11B40, 173rd Airborne Brig. - Vietnam Combat Veteran |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Sep 02, 2014 6:37 am Post subject: |
shortride wrote: |
If more or brighter lights make you fell more secure then go for it. |
I was kinda thinking the same.
sometime I'd be driving behind someone for ages and eventually realize their tail lights weren't working at all, whole time slowing down when they slowed down without even needing or noticing in fact the cues of a brake light. Even if they are driving 0.5km/h slower 200m up, I can tell I am catching up.
I tell you one thing, good brake light are very good to catch your eye when you are in the caught checking your mirror when traffic suddenly stops or slows down. _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
Posted: Thu Sep 04, 2014 11:42 am Post subject: |
From a common sense standpoint it would seem to be reasonable that the addition of a brief couple of flashes of brake light before solid on might be helpful in signaling a following driver that you are braking, especially in an older car built before the center high-mounted stop light mandate in 1985.
The CHMSL gives a very good visual indicator to following traffic that the brakes are on as opposed to just tail lamps. Especially for those vehicles that use the same bulbs for tail lamps and brake lamps as opposed to having two separate bulbs for that function. That strong visual signal could be replicated with the addition of an aftermarket LED CHMSL or just with the addition of a flasher as described above. With the stock setup, if someone behind you happens to look away just for that instant when your tail lamps transition to brake, it would be easy to miss that you have applied the brakes - just eats up more reaction time is all.
In reality, though, the real weakness of old VWs in terms of brake lights is the fact that the brake lights are lit via a pressure switch on the master cylinder as opposed to a switch that detects the motion of the brake pedal as on pretty much everything modern.
It would be better to have the brake lights come on with first movement of the pedal as opposed to waiting for brake pressure to build in order to give following drivers that much more time to react. Definitely not a good design on VW's part. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Sep 04, 2014 11:51 am Post subject: |
good point sjbartnik. The trucks I work on use pressure as well as motion switch for brake lights. I feel better knowing my brake lights will be noticed by the guy following me texting his girl that he is on his way. _________________ I think he meant "rare", as in "not well-done" |
Posted: Thu Sep 04, 2014 8:08 pm Post subject: |
But you still have to remember, it ALL depends on the idiot behind you, and whether or not he/she's paying attention.
What I'm getting at, is that IF he's texting his GF, he won't notice your lights flashing. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Sep 05, 2014 6:55 am Post subject: |
Bobnotch wrote: |
What I'm getting at, is that IF he's texting his GF, he won't notice your lights flashing. |
Yep, absolutely true. I just like to give them as much opportunity to notice as possible. At the end of the day, you can do everything right and still get screwed over. |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Tue Sep 09, 2014 8:07 pm Post subject: |
t3kg wrote: |
Josh very kindly lent me a CuLayer LED to test in my 6V Type 34. First of all, I have to say that the bulb is very well made. I can see why they cost what they do. In a Type 34 tail light housing the only socket that the bulb will come close to fitting in is the center one, which is intended for the tail light. It's a very tight fit -- I would say uncomfortably tight, because the bulb's heat sink bottoms out on the reflector and I had to struggle a bit to get the bulb back out after the test.
All that said, it did work, and the CuLayer bulb is REALLY bright.
So it can be done, but if you want to run CuLayers as brake lights in your Type 34 you'll have to rewire so that the brake light is in the center and the tail light is in the lower half. |
How much longer do you think the socket column would need to be to fit properly? 3-4mm? I'd guess that could be accomplished if requested.
It's hard to describe just how bright that bulb is when you see it in person, isn't it? |
