wrenchnride247 Samba Member
Joined: August 17, 2010 Posts: 251 Location: Cleveland, TN
Posted: Mon Aug 25, 2014 7:41 pm Post subject: |
I forgot to post the trans a few months ago so...
It's a '71 case (dual side cover, but late TO bearing) Stock German 3.88 R/P, 3.78 1st (out of SB), 2.06 2nd, 1.26 3rd, 0.89 4th, Super diff, HD cover, thrust plate, welded 3rd/4th, all splined gear sets (no keys), and of course, steel shift forks. This should handle any later power upgrades It also has all 944 NA brake hardware, and '68 axles and tubes. The long wheel studs have been replaced with shorter ones since pic.
_________________ SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4 |
dfusion001 Samba Member
Joined: January 13, 2011 Posts: 233 Location: Orlando
Posted: Wed Aug 27, 2014 6:10 pm Post subject: |
This is a sweet build man! Thanks for sharing!! |
kafer60 Samba Member
Joined: January 17, 2005 Posts: 363 Location: Fredericksburg, Va
Posted: Thu Aug 28, 2014 7:16 am Post subject: |
Welded CW 69mm cranks are getting $$$$ got this CB 4140 CW 69mm for better price.
Case ready to close (almost)
Did you have to clearance the block for the 69mm stroker crank to work? _________________ Can't polish a turd!
"Midman- Seems to have worked well for Ted Bundy."
"seems like the right front tire is flat at the bottom, rest looks pretty good"
"The hardest part about business, is minding your own" |
Posted: Thu Aug 28, 2014 5:05 pm Post subject: |
kafer60 wrote: |
Did you have to clearance the block for the 69mm stroker crank to work? |
No, 69mm is stock stroke. _________________ SPL
Posted: Sun Sep 14, 2014 9:40 pm Post subject: |
Motor in, and cam break in done! No leaks, and no bad sounds! Fuel filter location is temporary just so I could see fuel during break in.
schnidlee Samba Member
Posted: Sun Sep 14, 2014 10:55 pm Post subject: |
What are you using to grind your welds back? |
Posted: Mon Sep 15, 2014 6:13 pm Post subject: |
A 3M 3/32 thick cut off wheel to knock the top of the weld off 1st, 2" 36 grit disc on air angle grinder next, then 6" DA with 80 grit.
*note* keeping heat out the panel during welding and grinding are key to less hammer and dolly work. _________________ SPL
1967250s Samba Member
Posted: Mon Sep 15, 2014 11:59 pm Post subject: |
Your work is most admirable. Excellent. |
Posted: Tue Sep 16, 2014 5:54 pm Post subject: |
1967250s wrote: |
Thank you _________________ SPL
Posted: Tue Dec 09, 2014 8:40 pm Post subject: |
Sorry no pic, but have 2000 miles and my SC now . Will show some updates soon. _________________ SPL
BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1817 Location: Colorado
Posted: Wed Dec 10, 2014 8:30 pm Post subject: |
BDSBSS23 wrote: |
How do you like the motor? How does it pull? Easily goes 65 mph? Just curious cause Im building a motor similar to yours. |
It runs smooth and strong. A few steep hills around here slow it down. I have to admit though... I like a heavy right foot, and the 30pict carb was killing me, and never got the idle rich enough to my liking (didn't try real hard ) So, now it does have a set of dual 34's on it, and a stainless sidewinder header just showed up today! It's my main ride at the moment so, holding off on header till weekend. _________________ SPL
Posted: Thu Dec 11, 2014 8:32 pm Post subject: |
Crappy cell pic, but new carbs, and new "stock looking" CB serpentine pulley set up, "36 horse" shroud (modified for flaps and thermostat) 100 miles on it, and love it!
Posted: Sat Jan 24, 2015 8:27 pm Post subject: |
I finally have something good to show. I got a friend to stitch up a seat cover for me. I know its not correct for '62, but I'm happy with it. He also gave me the extra material, and I used that to cover my Werksberg ABS panels I got last week. I'll take it for a quick 100 mile spin tomorrow. It should be a little more quite now anyway.
Posted: Sat May 16, 2015 6:36 pm Post subject: |
I've been enjoying my SC so much, I have not posted much about it. It's been running like a top for 4000 miles now. So, here are a few pix from today cruising around my neck of the woods.
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Sun May 17, 2015 7:18 pm Post subject: |
Thanks Kurt, one day I will tear mine down to the level you are doing. But, until then, I'm driving the wheels off! _________________ SPL
Pinetops Samba Member
Posted: Sun May 17, 2015 8:47 pm Post subject: |
Nice pics! I was thinking there was something familiar about them and I just realized where they were taken. I've stayed at the HO campground many times. That old Webb Brothers station is really cool too. _________________ "A rolling bus gathers no rust." |
Posted: Mon May 18, 2015 6:22 pm Post subject: |
Pinetops wrote: |
Nice pics! I was thinking there was something familiar about them and I just realized where they were taken. I've stayed at the HO campground many times. That old Webb Brothers station is really cool too. |
Cool! This is 20 min from my house. _________________ SPL
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Fri May 22, 2015 9:49 am Post subject: |
wrenchnride247 wrote: |
Looking great! _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
