first rail, swing axle ???
kanddtowing
kanddtowing is offline
PostPosted: Wed Aug 27, 2014 9:42 am    Post subject: first rail, swing axle ??? Reply with quote
I just traded for this rail , it has tuning fork style trailing arm the right swing axle bearin housing appears to be a original vw part with the bump stop arm on it, the left housing has the bolt holes oriented a little different and has no bump stop arm, question is where can I get another housing like the left one?
jcmyers
jcmyers is offline
PostPosted: Wed Aug 27, 2014 10:31 am    Post subject: Reply with quote
http://www.pacificcustoms.com/ac501151.html
http://www.appletreeauto.com/REPLACEMENT-BEARING-HOUSINGS/
what has been done to that transmission? what motor was in it before?
kanddtowing
PostPosted: Wed Aug 27, 2014 1:30 pm    Post subject: Reply with quote
I have no idea about whats been done to it, it does have the adapter plate for and exhaust for a chevy 4.3 v-6. those links only show the housings with the bump stop arms, do they make one without or do I need to cut them off, if you look at my pics, the left one has no bump stop arm?
2RL
2RL is offline
PostPosted: Thu Aug 28, 2014 12:16 am    Post subject: Reply with quote
The part you're referring to as a bump stop is actually the stock lower shock mounting point. I would guess that; unless a part already exists which doesn't have the mount, that they just cut it off of the housing when they did the coil over conversion.
If it is a special made part just for that conversion, I have no idea where you'd find one at though unless somebody has one just lying around gathering dust somewhere.
Dale M.
Dale M. is offline
PostPosted: Thu Aug 28, 2014 6:44 am    Post subject: Reply with quote
Umm..... Dont see any bump stops, but what I do see is it looks like passenger side has long axle and a short axle on drivers side (could be just a visual because of image shadow and shock angle), .... Would also appear the passenger side was replaced after buggy was painted by somebody that did not follow the fabrication/design characteristics (see lower shock mounts - shock angles) of original build .... Not necessarily bad, just odd.... Needs to be refabed so both sides match....
Bump stop pads on axle are a non issue on this application as you have nothing at this point to contact them that I can see.... Also angle/location of brake calipers suggest right side was just a patch up repair job....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
kanddtowing
PostPosted: Thu Aug 28, 2014 9:47 am    Post subject: Reply with quote
thanks for the replys
