Barndoor front bean with adjuster
PastDown
PastDown is offline
PostPosted: Thu Aug 28, 2014 4:56 am    Post subject: Barndoor front bean with adjuster Reply with quote
Hi all,
Has any one fitted an adjuster to the standard BD beam? If so, did you use a normal bus or bug adjuster?
Any help would be grateful.
Thanks
Rob
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Thu Aug 28, 2014 7:12 am    Post subject: Reply with quote
You use a bus adjuster, though I would recommend constructing or purchasing a beam that uses later spindles(64-67). Beam tube spacing between tubes is the same. Save your original beam for restoration. Later spindles have better brakes and less expensive parts. The the higher price of parts to overhaul the OG bd brakes and kingpins just once will pay for a proper lowered beam using later components
Ian 68
Ian 68 is offline
PostPosted: Thu Aug 28, 2014 10:51 pm    Post subject: Reply with quote
The whole issue of lowering the front end is something I'm very interested in.
Ive asked questions, done searches and got few points of view on how to go about it but I'd be interested to know where you maybe able to buy a beam ready to go in BD ...have you got any info or links please as that could help a lot of people I reckon.
Best
Ian
kermie
kermie is offline
PostPosted: Fri Aug 29, 2014 12:03 am    Post subject: Reply with quote
Have a chat with Erwin @ Volksprojects, I believe he ships worldwide.
Ian 68
Ian 68 is offline
PostPosted: Fri Aug 29, 2014 1:49 pm    Post subject: Reply with quote
Thank you.
