grandpa pete Samba Member
Posted: Fri Aug 29, 2014 3:32 pm Post subject: Fixing rusty rims |
I just got 4 smoothies sandblasted.
I stopped by the tire store to ask if the pits on the rims would make them leak.........
The tire guy thought the tubeless tires would leak......
Any suggestions on how to fix this ?
Can I use a flap wheel to smooth out the edges ?
Can I put body filler in the pits....or...jb weld ?....or....??? _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Dirtylittle70Bugger Samba Member
Joined: February 21, 2005 Posts: 158 Location: Long Island, New York
Posted: Fri Aug 29, 2014 3:59 pm Post subject: |
So far in my time of mounting/dismounting and repairing VW and trailer tires by hand. I have yet to have a problem with a leaking bead from rust or minor damage. There's a lot of tire that goes along the wheel lip to seal it. As long as it's clean and free of debris you should be fine. If the wheels lip looks like it came out of the ocean then you might have a problem. I've had some fairly nasty looking wheels both steel and aluminum still seal up tight as a drum with no leaks. But a quick cleaning couldn't hurt. Flap or wire wheel should do te trick. _________________ I thought I was wrong once, but I was mistaken.
1967 VW Beetle, Java Green, 1500SP, Roof Rack, trailer hitch |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Fri Aug 29, 2014 4:20 pm Post subject: |
Pete, I use tubes in my 66 wheels, they dont have the safety lip on the bead so for me tubes are better _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Aug 29, 2014 4:24 pm Post subject: |
Common issues..
A nice good smooth bead of RTV in the bead area during mounting will seal the deal..
Case in point.. I just moved 4 tires from aluminum wheels back to pretty good stock steel wheels that I recently cleaned and painted.. The bead areas were actually pretty good.. some pits but nothing serious.. so I thought..
The next morning.. all 4 were flat... (with no prior issues)
I tried some super bead sealer..made specifically for bead leak repairs... NADDA!!
Flat in 2 days....
I simply applied nice coat of quality RTV sealer to the bead area on the wheel...
Mounted the tires with the sealer still semi wet....
Have yet to loose any pressure since..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
arizonabuckeye Samba Member
Posted: Fri Aug 29, 2014 4:43 pm Post subject: |
VOLKSWAGNUT wrote: |
Common issues..
Flat in 2 days....
Have yet to lose any pressure since..
After 6+ years working specifically on tires that is the way to do it. Be kinda quick with the bead sealer, slop a bunch on and seat the bead. The excess bead sealer will rub off easily.
Personally I wouldn't spend much time/money messing with it. Take it to Discount Tire. They will do the tires and rims "carry out" without being on your car. They will mount and balance for around $7.00 a tire and do flat repairs for free. If you have problems with your bead after taking it there, take it back. Spend your time finishing stuff that people won't do for free. |
Posted: Fri Aug 29, 2014 4:48 pm Post subject: |
..Well over 30 years for me....... On ALL Auto mechanical repairs...
Here lately.. "some" tire shops are refusing to mount tires on used wheels.. or used tires period...
Sad sad ... You can thank the litigating USA for that one.....
... _________________ aka Ken {o\!/o}
Usually and often edited |
Posted: Sat Aug 30, 2014 6:49 am Post subject: |
grandpa pete wrote: |
four 185/15 mounted , balanced ; on the car $263.... |
Use beads for balancing and dont look back....
http://www.thesamba.com/vw/forum/viewtopic.php?t=503595
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Sat Aug 30, 2014 8:34 am Post subject: |
That's a steal for tires. Around here, if you're looking for a set of 4, brand new, then count on spending out at lest $300, depending upon what size of tire (the $300 is the cheapest size) _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
Posted: Sat Aug 30, 2014 8:36 am Post subject: |
Dyna beads are the brand name for balancing beads. But on a budget you can also use regular BB's or heavy duty plastic airsoft BBs. I've never used the dyna beads myself. They are much smaller and should in theory work better than the larger BBs. Plus they fit through the valve stem if the tire is mounted. With BB's you have to break the bead to install them. I like BBs myself. Much easier to try to reuse them. I usually suck them up in a shop vac, clean them out in an old tea strainer and reinstall them in the next tire. The Dyna beads I hear can be a bit unpredictable when you try to corral them. _________________ I thought I was wrong once, but I was mistaken.
Last edited by Dirtylittle70Bugger on Sat Aug 30, 2014 12:43 pm; edited 1 time in total |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sat Aug 30, 2014 10:47 am Post subject: |
I had dyna beads put in my wide whites in March when they were mounted locally. (Millar Highway Tire, Canby, OR) they put them in at the same cost as they would have charged for lead weights. They ride like a dream.
They typically use the beads on big rig and tractor trailer wheels, and they were happy to try them on my beetle.
It's true; get the beads and you'll never look back. _________________ Plate of shrimp |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Mon Sep 01, 2014 12:50 pm Post subject: |
Lol. I once put a pile of golf balls inside a guys 35" truck tire. He swore by it. |
