Setting door and hood gaps
Braukuche
Braukuche is offline
PostPosted: Sat Jul 19, 2014 2:25 pm    Post subject: Setting door and hood gaps Reply with quote
Hey guys,
I am working on a '63 T-6 coupe and am working on my gaps. I have couple questions:
I know the gaps are supposed to be 3mm, but is that before primer and paint or after? Should I set my initial gaps larger than 3mm to allow for the primer and paint?
Also, my car is a Karmann body, but my hood is a Reuter hood. I have a fitment issue a the cowl. My corners match up fine, but in the center the hood is 1/4 lower than the cowl. Is this a compatibility issue?
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
MoPor
MoPor is offline
PostPosted: Wed Sep 03, 2014 5:42 pm    Post subject: Reply with quote
3mm is tight so I would say finished. Any replacement panel will require fitting.
Matt
'58 356A coupe
'00 Boxster S
