Yabbadubbadoo Samba Member
Posted: Fri May 30, 2014 9:24 pm Post subject: |
Got these images and article off the Vintage speed FB page. It's a write up about the Type 3 exhaust and Vintage Veedub's role in it coming to fruition. They are also my local aircooled experts so I'm often there making my contribution to the rent.
_________________ Sydney, Australia.
66 Type 3 Fastback |
fuhq64 Samba Member
Posted: Fri May 30, 2014 9:49 pm Post subject: |
Want so bad. Maybe if i ate Ramen Noodles for a month straight i could spring for it. Not sayin that the price isn't right, I'm just poor _________________ 69 Squareback
Still a n00b
www.instagram.com/fuhq64 |
Brent Samba Member
Joined: April 28, 2010 Posts: 1613 Location: San Tan Valley, AZ
Posted: Fri Jun 13, 2014 4:19 am Post subject: |
W1K1 wrote: |
For those that want to see the difference from the rear
The OTT sticks out and drags on steep driveways |
W1K1 - Did you notice any change in oil temps switching from OTT to this exhaust? I remember you and I both we're having some issues with a very similar motor/exhaust/full flow lines.
Reason I ask is there is a current thread in the Performance forum describing hot oil symptoms from full flow lines close to the header; which I have with OTT. Wondering if this exhaust would help? _________________ 69 Fastback Build
Berg5 Build |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4893 Location: Southern AB
Posted: Fri Jun 13, 2014 5:59 am Post subject: |
I haven't had it on a long highway run, but the sertrab cooler looks after the oil temp heat issue. I also have some oil line insulation wrap that i can use.
The head temp has dropped with the 1.1/2" VS the stock heat exchanger on the 1904cc with the better flow. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Brent Samba Member
Posted: Fri Jun 13, 2014 9:04 am Post subject: |
W1K1 wrote: |
The head temp has dropped with the 1.1/2" VS the stock heat exchanger on the 1904cc with the better flow. |
Good to know. My CHT temps were a bit high for my liking too. I'm ditching the OTT for this this exhaust when I move back. I'll live with a couple HP loss, if even, for the looks, fitment, and removal of the header that probably plagues my oil lines. _________________ 69 Fastback Build
Berg5 Build |
haz77 Samba Member
Posted: Sat Jun 14, 2014 1:24 pm Post subject: |
W1K1 wrote: |
You can pick your tubing size, this one is 1.5" with the sport muffler
Sounds good, i was worried when i fired it up, it was so quiet all i could hear was my noisy belt.
Video for thos that want to hear it
Thats just a picture not a video? |
W1K1 Samba Member
RennyRB Samba Textbook Gangsta
Joined: August 10, 2006 Posts: 979 Location: Torrance
Posted: Sat Jun 21, 2014 6:58 pm Post subject: |
Picked one of these up direct from Vintage Speed today at The Classic! Waiting for my car to cool down to install it. It's a very high quality looking piece, neat welds all around and a nice polish and a raised edge to the tip. The adjustable inlets should make installation a breeze, and ensure that the tip isn't resting on the apron. Super excited, and I normally hate doing exhaust work.
EDIT exhaust went on without a hitch, fits nice and sounds great. The tone at idle is much different than the over the top exhaust, less rumble to the vintage speed system. It is much quieter running, though. On the freeway I can't much hear the exhaust noise over the engine. Now, no more scraping in the rear with my car down two inner splines! I'm well pleased with it and would recommend it to others. _________________ 1967 Squareback |
Chino_UK Samba Member
Joined: January 08, 2014 Posts: 159 Location: Manchester, UK
Posted: Tue Sep 16, 2014 3:09 am Post subject: |
Really impressed with the look and sound of these, looking at getting one of these for when I take my original exhaust off for some extensive patching and restoring. Do they do away with the primary heater boxes on top? Anything I need to look for when changing exhaust (bearing in mind I've never changed an exhaust on an aircooled VW before)? Anything need blocking off etc? Any other parts I'll need to buy to fit? _________________ 1971 Iberian Red UK Type 3 Fastback
http://www.thesamba.com/vw/forum/viewtopic.php?t=584656 |
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Wed Sep 17, 2014 7:19 am Post subject: |
I am very happy with my VS. Here are a couple of pictures showing the engine out and in the car. It tucks in really nice. The fit is great. I ran hoses directly from the fan to my heat exchangers but you can use the upper heater boxes. I used the ones from Spruce.
I also have a remote filter and running the lines was really simple and they don't really get too close to the exhaust. I might add some insulation wrap on the hoses for extra protection.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Wed Sep 17, 2014 8:19 am Post subject: |
The Aircraft Spruce ducting is rated for 530 degrees I believe. Don't mess up your sweet looking engine wrapping them with anything! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Sep 17, 2014 8:54 am Post subject: |
Mike, the ducting from Spruce is good stuff. No issues there.
I meant the oil lines going to the remote filter. They run buy the exhaust and I will probably wrap some insulation around them for insurance. |
catbox Samba Member
Joined: May 16, 2007 Posts: 859 Location: Portland, Oregon
Posted: Thu Sep 18, 2014 12:48 pm Post subject: |
You forgot one of the cylinders.
Take it apart and start over....
_________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
bent_karma Samba Member
Joined: May 20, 2010 Posts: 291 Location: Modesto, CA.
Posted: Thu Sep 25, 2014 5:23 pm Post subject: |
That looks awesome! I wish I had money. Hey W1K1 how about you sell me your old exhaust for $50.00. _________________ '71 VW Bay Window Deluxe Bus [Busness] sold
'73 VW Thing [Agent Orange]
'71 VW Squareback (first air cooled/vw ever) sold
'07 Mazda3 Hatchback GT [the Mazda]
'06 Nissan Sentra 1.8 S (gone at the moment) sold
'18 Subaru Forester 2.5i [Sue Bee]
"Water is for drinking" |
W1K1 Samba Member
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Thu Oct 09, 2014 1:39 pm Post subject: |
They put them up already eh? Prices for these exhaust systems keep climbing. |
WD-40 Samba Member
Posted: Thu Oct 09, 2014 2:06 pm Post subject: |
catbox wrote: |
_________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Erik G Samba Member
Posted: Thu Oct 09, 2014 2:07 pm Post subject: |
JeeJeeJason wrote: |
extra pipe, extra welding, a little extra monies. Lots cheaper than a real Abarth |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3668 Location: San Jose, CA
Posted: Thu Oct 09, 2014 2:53 pm Post subject: |
Erik G wrote: |
Yeah...prices aren't "climbing". The single tip VS exhaust is still the same price. This new "Abarth" style exhaust is an iSP exclusive and is freaking awesome! It took all of my will power not to take it home with me last night... _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
