c.ruber Samba Member
Posted: Thu Sep 18, 2014 4:18 pm Post subject: Rocker goemetry changed.... |
I changed the thickness of the copper head gaskets and didn't take into account that the rocker geometry may change as well. I went from .060" copper head gaskets to .040" copper head gaskets. My question is can I correct my rocker geometry by adding shims under the rocker stands and still reuse my existing pushrods? I realize this has probably been covered here a bazillion times... Thanks for the advise. _________________ ...and progress is not intelligently planned... |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Sep 18, 2014 4:20 pm Post subject: |
yes u can do that u can also shave down the rocker too if u need to. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu Sep 18, 2014 7:55 pm Post subject: |
.020 is a small difference. Only enough to matter if your pushrods were bordering on too long before. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Thu Sep 18, 2014 8:37 pm Post subject: |
What cam? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri Sep 19, 2014 6:01 am Post subject: |
Dave, I'm running a Web 86b. _________________ ...and progress is not intelligently planned... |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Sep 19, 2014 8:29 am Post subject: |
Readjust lash and call it good. If geometry was done right like Modok said earlier, .020 mediation wont hurt nothin. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Fri Sep 19, 2014 9:00 am Post subject: |
Jfats, When I went to just re-adjust the lash, I couldn't because there wasn't enough adjustment at the rocker cup. I added shims under the rocker blocks and was eventually able to get close. I just want peace of mind. I have too much wrapped up in this engine to have a failure of some sort because I cut a corner just to get it back up and running. Thanks for any more info. I'll let you know how much shim I added under the blocks here in a few. BTW I'm also running a set of 1.45:1 rockers. Thanks _________________ ...and progress is not intelligently planned... |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Sep 19, 2014 10:47 am Post subject: |
c.ruber wrote: |
Jfats, When I went to just re-adjust the lash, I couldn't because there wasn't enough adjustment at the rocker cup. I added shims under the rocker blocks and was eventually able to get close. I just want peace of mind. I have too much wrapped up in this engine to have a failure of some sort because I cut a corner just to get it back up and running. Thanks for any more info. I'll let you know how much shim I added under the blocks here in a few. BTW I'm also running a set of 1.45:1 rockers. Thanks |
I understand. Worst case is a new set of mantons. But if the shims under the blocks work, get her up and running. _________________ 2276 IDA's 86C 11-1 DD !
Posted: Fri Sep 19, 2014 10:51 am Post subject: |
I'm confident the geometry was correct before. I did the whole process measuring for half lift with the dial indicator and the adjustable pushrod. I added .075" of shim on each rocker stand (all 4) to get the rockers to a point where I could properly adjust them. At this point I'm not real comfortable with the amount of threads sticking out of the adjusting nut. I've always stuck to the rule of thumb that there should be at least 1 1/2 to 2 threads showing outside of the jam nut. _________________ ...and progress is not intelligently planned... |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Fri Sep 19, 2014 11:58 am Post subject: |
.020 difference and didnt have enough room for adjustment? Gotta fix that, what happens when everything breaks in and starts to set and wear? _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
