Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Sat Sep 20, 2014 7:01 pm Post subject: Weight of Stripped Down 21 Window Bus/ Caster Rating? |
I searched around existing threads and couldn't seem to find the answer I was looking for; so hopefully this is not a redundant thread.
Would someone happen to know an approximate weight of a totally stripped down 21 window bus?
Totally stripped, no beam, no motor, no transmission, no windows, no mechanism, no seats, etc. The front doors and cargo doors would be on, but basically nothing else.
I'm getting ready to build either a dolly system or rotisserie to work on my bus and want to buy casters that will support the weight. I will use four total, two in the front and two in the back.
I was looking at these that will support up to 550lbs each.
http://www.grizzly.com/products/4-Heavy-Duty-Swivel-Caster-w-Brake/G8176
Or these that will support 600lbs each.
http://www.grizzly.com/products/5-Heavy-Duty-Swivel-Caster-w-Brake/G8177
I'm trying to keep the wheel size smaller because of height issues in my garage, but could probably even go bigger to a 6 inch wheel that is rated for a higher weight.
Any suggestions for the weight or caster to use?
Thanks for the responses. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sat Sep 20, 2014 8:59 pm Post subject: |
The unladen weight for a complete Deluxe is approx. 2500 Lbs. If you were to use casters with a capacity of ~500 lbs/each you should be good. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
58deluxerag Samba Member
Posted: Sat Sep 20, 2014 9:33 pm Post subject: |
I have a singlecab sitting on 10" pneumatic wheels rated at 350# at each corner and it's struggling. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sat Sep 20, 2014 10:39 pm Post subject: |
If you'll use 4 casters to support bus from rear spring plate & front beam attaching points, you'll probably have the engine, tranny removed + beam & all brakes. Guessing 2,500 minus 250 for beam... 400 for engine / tranny... 50 for rear brakes. That'd bring you to 1,800. 500 per caster should be good. If you're going to tip the unit, maybe consider getting a little higher rating. They probably have a factor of safety built in.... but I wouldn't push it too much.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
