Electrical connector removal
Forum Index -> Water-cooled VW Share: Facebook Twitter
partwerks
partwerks is offline
PostPosted: Sat Sep 20, 2014 7:21 pm    Post subject: Electrical connector removal Reply with quote
On the electrical connector on a 1996 VW Jetta, the pin connector that is right next door to the distributor cap with all the wires going into it.
To disconnect it, does a person twist it, then pull out? If so, it must be stuck? I'm afraid of breaking it, or does it come off that way??
ps2375
ps2375 is offline
PostPosted: Sat Sep 20, 2014 9:03 pm    Post subject: Reply with quote
Yes, it is a twist connector.
partwerks
PostPosted: Sat Sep 20, 2014 9:08 pm    Post subject: Reply with quote
Do you know which way it turns, if standing on the driver's side facing it. Clock wise, or counter clock wise.
I doubt if it has been off since new, and is probably stuck?
I hate to think of using a channel lock pliers, but have tried by hand, with no luck.
ps2375
ps2375 is offline
PostPosted: Sun Sep 21, 2014 8:44 am    Post subject: Reply with quote
CCW to remove.
partwerks
PostPosted: Sun Sep 21, 2014 9:08 am    Post subject: Reply with quote
I finally got it using a channel lock pliers. It was stuck, and heard a pop when it finally gave way. I was hoping it wasn't something more sinister, but found out it just unscrews. I gave it a good bath with MAF sensor cleaner was what I was after. Probably was never off since the factory?
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
