it_shua Samba Member
Posted: Sun Sep 21, 2014 1:43 pm Post subject: Question about Walk-Thru Bus anchor points |
I just got my first 1965 DeLuxe Bus (of my own) and I'm trying to find out whether these anchor points are stock or were fitted after market? I have one on each side of the Walk-Thru along with the same eye hole screws on either side were the after market seat belts would attach.
Any insight would be greatly appreciated!
Thanks!
Joshua |
Posted: Sun Sep 21, 2014 1:58 pm Post subject: |
zozo wrote: |
I use those belts on mine. Never had an issue with them. Use the giant eyelets to attach.
I searched by "Seat Belt" and found it after a little bit of looking. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sun Sep 21, 2014 3:00 pm Post subject: |
Probably VW dealer install.
http://www.thesamba.com/vw/forum/viewtopic.php?t=141026&highlight=seat+belt+mount
What will really tell you is if you look underneath and see if those spots are reinforced properly.
Before 1967 it was unusual to get a VW Bus with factory seat belts. _________________ In Stereo, Where Available!
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun Sep 21, 2014 3:40 pm Post subject: |
Now I'm curious. What would I see underneath to prove or disprove factory vs dealer? |
zozo Samba Member
Posted: Sun Sep 21, 2014 4:05 pm Post subject: |
Just went out and took a pic of each side, just the outermost mounts, from underneath. Factory? Dealer? It does have the 425 m-code, FWIW.
There is Velvet Green on the mounting hardware. Would that likely indicate factory mounting?
srfndoc Samba Member
Factory support bracket:
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Sun Sep 21, 2014 5:18 pm Post subject: |
zozo wrote: |
Just went out and took a pic of each side, just the outermost mounts, from underneath. Factory? Dealer? It does have the 425 m-code, FWIW. |
Factory supplied VW dealers with parts for those... Paint on them might be factory or if there was a respray... 425 should include seat belts if that info is correct. So would guess that they are factory installed. _________________ In Stereo, Where Available! |
zozo Samba Member
Posted: Sun Sep 21, 2014 5:38 pm Post subject: |
Eric&Barb wrote: |
zozo wrote: |
Factory supplied VW dealers with parts for those... Paint on them might be factory or if there was a respray... 425 should include seat belts if that info is correct. So would guess that they are factory installed. |
Cool. Thank you. |
Posted: Sun Sep 21, 2014 7:04 pm Post subject: |
Glad to help! _________________ In Stereo, Where Available! |
Posted: Sun Sep 21, 2014 9:11 pm Post subject: |
Just did a quick search of the vintagebus.com bus registry for M 425. Out of 5173 buses in the registry, there are 1018 buses with that Mcode. So about 1 out of 5 buses. _________________ In Stereo, Where Available! |
Posted: Sun Sep 21, 2014 9:36 pm Post subject: |
I just looked at my plate and (425) - - Mounting for safety belts in driver's and passenger's compartment |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Wed Sep 24, 2014 6:32 pm Post subject: Re: Question about Walk-Thru Bus anchor points |
it_shua wrote: |
Thanks!
Joshua |
Those look like ankle busters to me...unless you don't actually walk through the walk through.
The storage under the driver's seat is a good place to keep band aides.
My '67 walk through had the shouldered bolts with the plastic grommets. They kept the belt end close to the sides of the walk through and the plastic grommets held the belt end stiff enough that it kept the belt orientation proper so as not to end up with a twisted belt on your lap.
Although I've still managed to hack my ankles open with them too.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
