BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1817 Location: Colorado
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Sat May 03, 2014 7:23 am Post subject: |
ok some updates. I have been working on the floor and came across some issues but however i believe i got it fixed up. Ill show you pics of what issues i had with the floor
As you can see the gap between the headlight support
in order to make the floor to fit i have to adjust the corner to get the floor to touch the headlight support which has been done now. I will post pics once it is welded on
received the nose from Wolfsburg. Very nice quality, it will do just fine fixing up the bus' nose.
The pillar is finally welded on the valance.
Dogleg is a little bit of an issue because it's about 1/8" from the pillar on the bottom so I think I'll try to pull it in about 1/16" because I don't want to stretch the metal too much. I have measured and compared the drivers side, everything is spot on.
also got bumper bracket along with the nose
Hopefully soon ill weld the dogleg then the last piece is the floor. _________________ 58 beetle AKA Black Beauty http://www.thesamba.com/vw/forum/viewtopic.php?t=496780&highlight=black+beauty
65 micro bus (project)
http://www.thesamba.com/vw/forum/viewtopic.php?t=522611&highlight=std
Pillar repair with 65 bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=530360 |
1967250s Samba Member
Posted: Sat May 17, 2014 12:49 am Post subject: |
Man,you are one determined Dude. excellent work. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2077 Location: Bulli Klinik, Colorado Springs
Posted: Sun Sep 21, 2014 10:05 pm Post subject: |
You're doing a nice, complete job. You may consider removing the headlight bucket in order to metal finish the nose once it's welded in place. The bucket can be welded back in with no distortion or visible welds once the nose is cleaned up. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Kiwinw Samba Member
Joined: March 28, 2014 Posts: 58 Location: Portland, Oregon
Posted: Tue Nov 04, 2014 5:20 pm Post subject: |
glideking wrote: |
Good progress. Those plug welds in the very corners are hard to grind. You're not kneeling in the snow anymore!
Kurt |
how do you grind welds in the corners? I've been struggling with this on quite a few locations where I'm trying to weld in patches. |
vwserphguy Samba Member
Joined: April 30, 2009 Posts: 175 Location: Vail Valley
Posted: Sun Nov 09, 2014 6:59 am Post subject: |
X2. And lots of cutting (dremel) wheels. Nice job btw. I know this is time consuming work but once it's behind you... Soooo rewarding! _________________ "Relax and just enjoy the ride knowing everybody passing is wishing they had one." |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Posted: Sun Nov 09, 2014 11:58 pm Post subject: |
Looks pretty good! I am glad to see that I am not the only one who had fitment issues with the WW floor. Are you planning to use the entire lower nose panel or just the part you cut out? I'm curious about how it fits vs. Gerson's panel. _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
1978 Westfalia Camper
Transmissions For Dummies
