Splated Samba Member
Posted: Mon Sep 22, 2014 8:27 am Post subject: |
Is there an easy way to wire into the bugs tail lights? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Sep 22, 2014 8:45 am Post subject: |
yes, under the hood where they branch off to the rear
Or magnetic tow lights work good too _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Sep 22, 2014 8:49 am Post subject: |
60ragtop wrote: |
Or magnetic tow lights work good too |
Is there instructions some place?
The diagrams are hard to follow.
Posted: Mon Sep 22, 2014 8:57 am Post subject: |
http://www.thesamba.com/vw/archives/info/wiring/bug_7071.jpg
use this diagram, the rear tail light wires are specific to the colors where they go, easier to follow. _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Sep 22, 2014 9:39 am Post subject: |
I think magnetic tow lights are looking better and better. lol |
Posted: Mon Sep 22, 2014 11:02 am Post subject: |
Thats where I was planing to get the chains, ball, lights, and a batt kill switch, tomorrow, today I'm picking up the tow bar.
I'm planing to haul some bulky but light weight stuff in the bug, as long as i keep the weight balanced should be fine right? |
Posted: Mon Sep 22, 2014 12:21 pm Post subject: |
yep I moved from CO to Wyo towing my 60 and had it packed with stuff.
Just makes sure nothing can bump the shifter into gear
And with some of the lights the magnets are not very good so additional help maybe required; tape, zip ties etc _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Sep 22, 2014 12:53 pm Post subject: |
i was planing to zip tie them to the hood vent holes or something |
Posted: Mon Sep 22, 2014 1:08 pm Post subject: |
U HAUL used to sell a tow light kit that you could hook under the decklid/trunk with a flap, you might check that out too. I have a set of them also. _________________ Rick
tasb wrote: |
sb001 wrote: |
KennyK Samba Member
Joined: January 24, 2012 Posts: 51 Location: foothills of NC
Posted: Wed Oct 01, 2014 5:34 am Post subject: |
Here is my 2 cents, as I have towed from CA to NC with tow bar.
1. Saftey chains! Make sure you use saftey chains from tow bar to tow vehicle and from tow bar to vw.
2. You can replace the pins and clips with bolts and double nuts or nylock nuts.
3. A Light kit can be picked up at Harbor Frieght for cheep.
4. Make sure you get the correct ball tow bars come in ether 1 7/8 or 2 in so double check.
5. If your car is lowered you might want to remove bumpers and make sure you get a the tow bar riding level get a drop hitch and turn it up or down to raise or drop ball hight as needed. I hope you do have a receiver hitch and are not planning on towing from bumper!
Plan ahead double check everything, chech it every time you stop for fuel or food and remember you have extra weight that has no brakes on it and will trying to push you when you try to stop so allow extra room. Don't Tailgate!
Take care of any tire or bearing issues before you leave and make sure brakes are not draging
After all that hammer down and enjoy the ride. I did and had a good time no problems I'be done it twice now. And might be doing it again real soon working with a guy in CA bout his car. |
Posted: Wed Oct 01, 2014 7:38 am Post subject: |
I'm going to bumper tow. but the Tacoma's bumper is able to handle it, (I did research)
I had to do a unexpected test when the bug broke down on me.
I have the Tow lights and chains, both from harbor freight. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Oct 01, 2014 4:28 pm Post subject: |
If your tow ball really must ride that high- I'd either shift the load in the truck toward the tailgate a bit (level it out) or expect the tow bar to lift the front of your bug, using the apron as a pivot, on occasion going over dips. _________________
EverettB wrote: |
FU#5 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Oct 07, 2014 4:27 am Post subject: |
blue72beetle wrote: |
Now I'm wondering... if one were really paranoid about flat towing, would it be more advantageous to remove the axles? |
The only benefit would be satiating the paranoia
The only caveat to a tow bar approach is don't overload the towed car with stuff, and make sure nothing can fall and knock the car into gear while towing
Towing anything, it's a good idea to stop every two hours and check your tow load. You probably need safety chains and a light solution of some sort to keep the cops at bay _________________ .ssS! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Tue Oct 07, 2014 6:59 am Post subject: |
Wow.....
1. With the back of the Tacoma filled with all of your possessions, two people and the bug on tow bar.....I can guarantee that you are barely inside of the capacity of that rig for towing...weight wise.
2. Much as I love a standard trans.... its going to be hard on the clutch when you get into hills or heat
3. I cant believe no one here suggested having one of the excellent transport companies haul it for you. The fact that its a roller, is small and light. ...plus mileage an the cost of fuel is down slightly. .....you could have had it trailered enclosed.....for about $850 or so.
Ray |
