71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
dweiss76 Samba Member
Joined: July 13, 2014 Posts: 17 Location: Toledo, Ohio
Posted: Tue Sep 23, 2014 1:53 am Post subject: |
cool. I am also going to fit thornbirds on my 56 baja. Was going to do 30x11.50 but seeing you got 33's I may as well get the 31x12.50's. How to thet clear on the front when turned lock to lock? Also put up more pics with those tires please. |
dave-in-indiana Samba Member
Joined: September 21, 2014 Posts: 13 Location: Fort Wayne
Posted: Tue Sep 23, 2014 7:59 am Post subject: |
I am in the process of putting together a long travel front end. Not sure of interference issues yet. When I run into them I will post the problem and the solution that I used to solve it. At this stage it is more of a "mock-up" then the finished product. I believe the 33s will work fine using some creative clearance solutions. I will put more photos up of the tires, soon. |
winchin73blazinbaja Samba Member
Posted: Tue Sep 23, 2014 9:12 am Post subject: |
on my 74 baja with 31/10.5/15 bfg km2's i have rub at full turn if i hit a bump on the inside of the inside rear of the tire. planning on cutting the wheel wells out and hammering out new ones and welding them about an inch back and and 1.5-2" inward to make some extra room for tire clearance. it all depends on backspacing also unless you are really beefing up the pitman arm and tie rod ends you will be seeing some increased wear on the steering components.
my pitman arm was already starting to elongate on the passenger side when i purchased it but it definitely became more noticeable after about 2-3 weeks of driving it with my 31's mounted. |
Posted: Thu Sep 25, 2014 4:28 am Post subject: |
Had to take a few days off, work and family commitments. The original ideas I had for the suspension on this project are going to need rethinking. Starting with the front end, these tires are going to require a wider beam to make it work correctly. That being said, I am looking at other peoples successes with long travel frontends. I think that I am going to attempt to build my own double beam front end. In the meantime after the kids football games, choir recitals, church and dinner with the wife's side; I will try and post pictures of the roll cage and how the suspension seats are mounted. Anyone with success/failure with fabbing their own beam, comments and ideas are welcome. |
