zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Aug 17, 2009 2:57 pm Post subject: |
I made mine out of plexiglas via the following:
Should you find yourself in need of some plexiglas cut to a specific dimension, you only need to remember this:
Leave the paper on it
Trace or draw your shape
Use a jig/scroll saw
medium speed
18-20 tooth per inch blade with a ZERO offset
Coarser blades, positive offset, or too much speed can cause melting or cracking.
Once completed, DO NOT pull off the paper. Sand the edges with 600, then 1000, then 1500, then 2000, then rouge to get that glassy edge. You can also melt the edge to get the shine, but try your technique of a scrap first, as you can actually ignite the plastic, much less the paper. OR you can do what I did and leave it well enough alone.
For the rivets I went to ebay and searched on "press rivets". Got several hundred of them for next to nothing.
dawerks Samba Member
Posted: Mon Jan 24, 2011 10:54 pm Post subject: |
Bumping this thread because...
..how do you take them apart? Did you drill out the rivets? |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Tue Jan 25, 2011 3:48 pm Post subject: |
Yes, drill out rivets. _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
Posted: Tue Jan 25, 2011 3:49 pm Post subject: |
zozo wrote: |
medium speed
They look great! _________________ Hoockd on fonicks werkt for mee?
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Thu Jan 27, 2011 4:54 am Post subject: |
As for the boards I had great success with scrubbing them with a toothbrush and some paint remover. Took all the paint out of the pressed pattern. They came up really well with some rattle can paint and the rechromed frames. Perfect _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Kina's Bus Samba Member
Posted: Tue Mar 01, 2011 11:39 pm Post subject: hard board demensions |
Can anyone give me the demensions of the old school type hardboard visor. I want to see if I can make some myself since there difficult to locate at a reasonable prince. Thanks |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Mar 02, 2011 6:46 pm Post subject: |
I sense a trend here-
I think I have an extra original visor. I'll look and see if I still have it. What do you consider a "reasonable" price?
Oh, and a warning about the plastic visors. The woman who bought my bus pictured here, ended up wrecking it and gashed the heck out of her forehead on the visor. Blood ALL over the place! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
zozo Samba Member
Posted: Thu Mar 03, 2011 1:43 pm Post subject: Re: hard board demensions |
Kina's Bus wrote: |
Do you need the whole assembly, or are you looking to replace just the hardboard? I may have just the board that I removed from one of those that I put plexiglass into. At the very worst, I could trace it and send you the tracing. |
Posted: Thu Mar 03, 2011 2:42 pm Post subject: hardboard visor |
Dude that would be awesome! Heire's my e-mail address [email protected] shoot me an e-mail and I'll send you my address. Thanks so Much |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Sat Apr 23, 2011 12:02 pm Post subject: |
figured I'd ask here,
Is there a way to fix the padded style visors from not staying "up" anymore. They no longer are firm against the chrome rod, and just fall down fairly easily.
Thanks. _________________ 1957 Beetle
1966 Bus |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sat Apr 23, 2011 1:48 pm Post subject: |
GLHTurbo wrote: |
Thanks. |
tighten the screw. _________________ .
Wanted:
LuckyMonkeyGarage Samba Member
Joined: September 11, 2001 Posts: 937 Location: Arizona up north, near a mountain with a big "J" on top of it
Posted: Wed Feb 27, 2013 3:26 pm Post subject: |
Here's a NOS one to compare for restorations...
_________________ http://ghostwagens.blogspot.com/
http://vintageswampcooler.blogspot.com/
..........._I====I_ ......................................
......__//_i_||___\\...........i---------------------i
.-==--|''''''''~|''''''''-=-........i---------------------iD
/( O )\\____|__/( O )\\==...........( o ).......... |
zozo Samba Member
Posted: Wed Feb 27, 2013 4:06 pm Post subject: Re: hardboard visor |
Kina's Bus wrote: |
Damn! I never saw this post.
Still have the board though. |
jeffavatech Samba Member
Joined: March 01, 2009 Posts: 141 Location: Titusville, Florida
Posted: Mon Aug 18, 2014 11:01 am Post subject: New visors |
My new visors |
kirbyland Samba Member
Posted: Mon Aug 18, 2014 7:31 pm Post subject: |
Are the press rivets chrome? I couldn't find any on e-bay. Do the boards come out very easily, with out damage, once rivets are drilled? Need a special tool to press them? Thanks |
Posted: Mon Aug 18, 2014 10:07 pm Post subject: |
I just drilled mine out. Used 3/16" dark smoke plex, filed the edges so it would fit in the frame easier. I used small screws and nuts to secure it. Works good, now I can see when they are down. |
Posted: Tue Sep 30, 2014 6:35 pm Post subject: |
Still can't find the chrome press rivets- I want to rechrome my frames, but don't dare take them apart without the rivets- Any help? |
zozo Samba Member
Posted: Tue Sep 30, 2014 7:08 pm Post subject: |
Sorry about the PM a minute ago. I'm out of town on business until Friday. Shoot he a reminder PM on Friday and I'll find them for you. I KNOW I have lots of them left and will be happy to share. |
busworks Samba Member
Joined: May 21, 2004 Posts: 201 Location: Moncks Corner,S.C.
Posted: Sat Oct 04, 2014 6:00 am Post subject: |
X2 on the rivets. Looking for them to do this upgrade also.
Thanks, Dan |
