bigvwhead Samba Member
Joined: January 01, 2009 Posts: 202 Location: Karlstad MN
Posted: Tue Apr 03, 2012 2:52 pm Post subject: |
"LIKE" Thats how every winter storage should go (my 58' bug was that way this year) see ya in Co.
Happy motoring _________________ '65 Karmann ghia
'65 500,000 mile bug (og motor-trans)
'65 Twin Turbo Ghia (in the works)
'66 double cab
'66 bug |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Apr 06, 2012 6:54 pm Post subject: |
with the cool weather so far this spring, the idle was a little low, so a simple bit of fiddling with the idle set screw and everything is OK again... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sun Apr 22, 2012 6:57 pm Post subject: |
no pictures, but replaced the engine cover seal with the seal from ISPWest - fit like a glove, a little 3M gorilla snot in the channel and away we go...
also, picked up the jailbars from the powder-coater... they are almost too pretty to put on my car... I need to get some mounting screws and install them... _________________ póg mo thóin
vwfye Samba Member
Posted: Sun Apr 22, 2012 8:29 pm Post subject: |
how much more quiet now? _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Mon Apr 23, 2012 2:45 am Post subject: |
vwfye wrote: |
how much more quiet now? |
about the same - it wasn't noise that alerted me to the failed seal, but the intrusion of engine/exhaust fumes in the cabin... _________________ póg mo thóin
dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Mon Apr 23, 2012 6:27 am Post subject: |
I forget; on the engine lid seal: is it groove side up or down? _________________ 1963 Karmann Ghia |
Posted: Mon Apr 23, 2012 6:33 am Post subject: |
dc wrote: |
I forget; on the engine lid seal: is it groove side up or down? |
up! _________________ póg mo thóin
vwfye Samba Member
Posted: Mon Apr 23, 2012 8:00 am Post subject: |
hey Blank... with the carb mods, where did your before/after MPG come out? _________________ 64 No'back Speedster "Pearl"
Posted: Mon Apr 23, 2012 8:38 am Post subject: |
vwfye wrote: |
hey Blank... with the carb mods, where did your before/after MPG come out? |
so far, the Solex's are about as economical as the Webers - I gained about 2 mpg, mainly probably due to the Webers were jetted rich...
it really doesn't seem to matter, as I normally drive it less-economically than I should...
right now I am getting 26 to 28 mpg; if I drove it more daintily, I can imagine 30 mpg easily... _________________ póg mo thóin
vwfye Samba Member
Posted: Mon Apr 23, 2012 9:33 am Post subject: |
when you changed the venturies, did you up the main jet size? _________________ 64 No'back Speedster "Pearl"
Posted: Mon Apr 23, 2012 9:34 am Post subject: |
vwfye wrote: |
when you changed the venturies, did you up the main jet size? |
yes - somewhere here in the build thread is the set up we settled on....
EDIT:
26mm venturi's in them, 137.5 main, 175 airs, 55 idle pilots... _________________ póg mo thóin
vwfye Samba Member
Posted: Mon Apr 23, 2012 9:39 am Post subject: |
thanks man! if i ever build another 1904, my carbs will get that mod. _________________ 64 No'back Speedster "Pearl"
Posted: Mon Apr 23, 2012 9:43 am Post subject: |
vwfye wrote: |
thanks man! if i ever build another 1904, my carbs will get that mod. |
obviously, you'll probably need to increase the jetting a bit compared to my 1776, but you'll have a good starting point... _________________ póg mo thóin
Joser11 Samba Member
Joined: December 03, 2008 Posts: 60 Location: San Juan, Puerto Rico
Posted: Mon May 14, 2012 6:20 am Post subject: Sport headlight kit |
Was this the sport headlight kit that you used?
http://www.mamotorworkstv.com/vw/product/sport-hea...ir_303101/
If so, how are they standing up to weather and time ? Have the lenses turned hazy?
Bout to buy some bot on the reviews in the website a fellow said that the lenses turned hazy.
How are they holding up ? |
Posted: Mon May 14, 2012 6:22 am Post subject: Re: Sport headlight kit |
Joser11 wrote: |
they are holding up great - the lenses are glass and are not hazy at all... _________________ póg mo thóin
Posted: Mon May 14, 2012 7:07 am Post subject: |
Thanks.
If yours are glass then the ones I am looking at (ones in the link) are not the same as they are made of plastic.
Could yo provide me with the links to the ones you bought? |
Posted: Mon May 14, 2012 9:37 am Post subject: |
Joser11 wrote: |
Thanks.
that link appears to be the same ones that I purchased several years ago - if they are plastic now, they've changed the headlights.... _________________ póg mo thóin
Posted: Sun May 27, 2012 10:51 am Post subject: |
back to the jailbars:
test-fitting:
rear fitting:
driver's side:
passenger's side:
from the rear:
inside view:
Shaven Samba Member
Joined: September 17, 2006 Posts: 879 Location: Australia
Posted: Sun May 27, 2012 8:46 pm Post subject: |
found them... very nice. they look great _________________ the dc baggin is because its a well known fact that a restored sc will never be worth anywhere near what even a shitbox dc is |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Oct 02, 2014 12:01 am Post subject: |
sweet any recent updates? have you still got it? i gotta read this whole thread...someday.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
