Raymond73 Samba Member
Posted: Sat Mar 05, 2011 8:52 pm Post subject: |
EverettB wrote: |
If anyone has a product they can recommend for Windows7, please post it here so I can add a link to the first post in this thread.
Thank you. |
Windows Paint that comes pre-installed will resize pictures. Just make sure to select the Maintain Aspect Ratio so it doesn't look all weird.
I am using Windows 7 (64 bit). Gimp version 2.6.11 works fine on my computer too.
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 306 Location: Marietta, GA
Posted: Fri Aug 17, 2012 7:11 am Post subject: |
I use Picasa 3 on my computer to resize photos for the gallery.
Highlight the pictures to be exported and select "File", "Export Picture to Folder . . . .". A screen will appear for the destination and a slide to select image size. I left it on 800 pixels. The photos are copied to the folder I created; from here they can be uploaded to the gallery. |
kevnmarcie Samba Member
Joined: December 11, 2006 Posts: 94 Location: Poulsbo, WA
Posted: Mon Aug 25, 2014 9:43 am Post subject: |
Is there anything available for Windows 8.1? I am still trying to figure out this system after years of being perfectly happy with XP. The only way it wants to let me upload to my Samba ads is through OneDrive - which I am highly suspicious of, because it seems to want to copy every file on my computer. I also have not been able to find a resizer through this method. I would prefer to resize the pic on my machine and then upload it to my Samba ad directly from my machine. If anybody has any pointers, I would sure appreciate them.
Baffled by new technology...
Thanks,
Kevin |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Fri Oct 03, 2014 8:35 pm Post subject: |
Thanks Everett,
I downloaded the Windows 7 version. When I click the Browse button in the ad form, it brings up the OneDrive page in 8.1. I've discovered that if you click the down arrow next to the OneDrive header, you can select This Computer and access the pictures stored on your machine. They will resize automatically when they are posted to the ad. |
MaximumFinishes Samba Member
Joined: August 23, 2014 Posts: 100 Location: Donnelly,ID
Posted: Mon Oct 27, 2014 7:58 am Post subject: |
There is an adjust size feature in the edit section of preview for Macs. _________________ '64 Type 3 "Noback" - Frank
'68 Squareback - Charlie
'73 Westy - Mac
'98 Honda CR-V - Dee
'97 Subaru Impreza Outback - Dennis |
jimf909 Samba Member
Posted: Sun Sep 04, 2016 11:17 am Post subject: Re: Photo Resizing |
Is there a recommended solution for shrinking photos to avatar size on an iPhone? I've downloaded several resizing apps and none shrink photos down to 12 kb.
Any tips welcomed! _________________ - Jim
Abscate wrote: |
Posted: Mon Sep 05, 2016 8:20 am Post subject: Re: Photo Resizing |
jimf909 wrote: |
Any tips welcomed! |
Do you know what size it's getting down to with the software you are using?
This is a common problem for people, I bumped up the size to 20KB as of right now to see if that helps. _________________ How to Post Photos
Jan Steinman Samba Member
Joined: July 03, 2022 Posts: 175 Location: Bellingham, WA, USA
Posted: Tue Sep 27, 2022 12:51 pm Post subject: Re: Photo Resizing |
Avatar won't accept. "400 Bad Request — cloudflare".
I see a lot of people on this ancient thread saying it has to be under 100x100 and under 6kb.
But the instructions right under the "Choose file" button says, "width can be no greater than 120 pixels, the height no greater than 120 pixels, and the file size no more than 64 KB"
So, I made a 120x120. Size was 7kb. It won't take it.
So, in case the text under the button was wrong, and the ancient (~2007) requirements in this thread are right, I made an 80x80, under 3kb. Still won't take it. Same error message. This was an image stripped of all EXIF info.
Is anyone able to change their avatar? Do you need so many "points" or something? Is there a secret password?
Thanks! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Tue Sep 27, 2022 12:57 pm Post subject: Re: Photo Resizing |
It was increased to 120x120.
Is your image a .jpg? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Sep 27, 2022 2:24 pm Post subject: Re: Photo Resizing |
Glenn wrote: |
Is your image a .jpg? |
Yes. Here it is.
Whoops. Won't let me load it in my gallery, either.
Let's see if this works…
That's the same 120x120, uploaded to Flickr, but if I put that URL into the "URL" field for my avatar, it returns immediately after "Submit", and the avatar isn't installed.
Strange. |
Posted: Tue Sep 27, 2022 2:44 pm Post subject: Re: Photo Resizing |
EverettB wrote: |
I don't know what went wrong - I uploaded it into your profile and it worked fine for me.
It may be different than your original as I can see Flickr modified it internally |
YAY! Thank you! I be avatar'd now! |
