Erco zero offset with front disc brakes
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
rrcade
rrcade is offline
PostPosted: Wed Oct 01, 2014 7:23 pm    Post subject: Erco zero offset with front disc brakes Reply with quote
I've read some Old posts where people have got these to work without spacers. Is anyone currently running wide 5 zero offset ercos in the front with disc brakes on a link pin front end? If so which disc setup are you running? I'm hoping to have drop spindles as well without spacers. Is this possible?
Thanks
rrcade
rrcade is offline
PostPosted: Sat Oct 04, 2014 6:37 am    Post subject: Reply with quote
OK, lets try this......evidently CMS is working on Zero offsets for the front that will clear all disc brakes, anyone know anything about this?
MarvinNash
MarvinNash is offline
PostPosted: Tue Dec 16, 2014 6:13 pm    Post subject: Reply with quote
Airkewld bad series stage 3 brakes up front. Had to grind the caliper about 1mm.
Airkewld
Airkewld is offline
PostPosted: Tue Dec 16, 2014 7:57 pm    Post subject: Reply with quote
#winning
TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba
rrcade
rrcade is offline
PostPosted: Thu Jan 22, 2015 10:15 pm    Post subject: Reply with quote
What else you got going on in the front? Drop spindles, narrowed?, adjusters,etc? I like your stance I'm trying to figure out what route I want to go in the front right now
VeloMikey
VeloMikey is offline
PostPosted: Wed Feb 04, 2015 11:38 am    Post subject: Reply with quote
Here you go... $239 each.
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
rrcade
rrcade is offline
PostPosted: Wed Feb 04, 2015 6:57 pm    Post subject: Reply with quote
Of course they come out after I buy a set of Ercos, the Hell with it I'm gonna put drop spindles on and run drums up front seeing how nobody in the whole world is running ercos with disc brakes and can tell me which disc kit fits.
Someday I'll upgrade and probably get these rims, I'd love to see a pic of them on a car.
vdub8
vdub8 is offline
PostPosted: Wed Feb 04, 2015 9:21 pm    Post subject: Reply with quote
I'm running ERCOs and Airkewld front disc. I chose to run spacers rather than modify calipers, etc. The caliper had basically no clearance and the brake pad retaining pin interference was at least .25".
My 67 build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=448654
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
