Barndoor51 Samba Member
Posted: Sun Jun 15, 2014 3:56 am Post subject: |
Yes we have _________________ 20-03194 Panel
20-011384 Kombi
20-110724 SingelCab
January -58 double cab "the Swedish Binz" |
Hellberg Samba Member
Posted: Sat Jun 21, 2014 2:49 pm Post subject: |
Got some parts from Autocraft recently!
Looks really good and most of it seems to fit well!
I've kept building the chassis, measured it 1000 times and 1000 times still to measure Need to get it really straight
Some booring problems I've to fix..
Measured it 100 times here and it seems like the outrigger is to long but I'll fix that! I Really don't think it should be bent like that, but if it should please tell me
And I just had to test one thing before I went home!
Really good for my motivation!! _________________ Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
...........Driving barndoor to HO 2017............ |
Posted: Sat Jun 21, 2014 3:04 pm Post subject: |
henry roberts wrote: |
love it.
do all you Swedish guys have huge yards, huge sheds, trucks and heavy plant? nearly every Swedish thread seams to show big yards, big sheds and lots of heavy lifting gear. |
I wish I fixed my 57 oval in my garage at home, couldn't almost walk around the car because it's so tight... Now, I'm lucky who have bigger garage to be in. I'm only usin half of the garage So much easier to work with the right stuff! _________________ Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Sat Jun 21, 2014 5:29 pm Post subject: |
Hellberg wrote: |
Really good for my motivation!! |
Nice work. It looks like you are going for standard ride height _________________ Jack Staggs
Actual name |
Stetoppingphoto Samba Member
Joined: February 15, 2012 Posts: 475 Location: Darwen
Posted: Tue Jul 08, 2014 8:07 am Post subject: |
Looking good! look forward to seeing it at HO awesome show to target for
subscribed. _________________ stetoppingphoto |
Posted: Tue Jul 08, 2014 1:13 pm Post subject: |
I don't think I will go for standard heigh, but maybe sometime
I've made some progress but not that much..
Since the whole lower front needed to be pulled back about 2 cm I used special screwes for this!
Welded them in place and look now!
There was a 2 cm gap between the door and the B-pillar!
I also remounted the front beam and got it down on earth for a minute I actually did this before a pulled back the whole lower front, the make it easier!
I've also done this so far!
I will mount it in with wheels and then put in the middle chassis section I think, like mark did with the kempes bus! _________________ Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
spit nolan Samba Member
Joined: March 08, 2005 Posts: 123 Location: redditch, united kingdom
Posted: Tue Jul 08, 2014 3:32 pm Post subject: |
God work dude, I bloody love this bus! |
Posted: Sat Oct 11, 2014 1:51 pm Post subject: |
The logo on the left frontdoor was overpainted, took it away and the logo is back.
Also found an old picture of one of the Modo buses from the days!
Started with cutting a piece of metal out and then bend it to make a piece for the wheelwell
Cut.
Weld
von_hansel Samba Member
Joined: June 12, 2006 Posts: 635 Location: Inland Empire
Posted: Sat Oct 11, 2014 9:10 pm Post subject: |
Sick Dude!
Can't wait to see your next update
Posted: Sat Oct 25, 2014 10:30 am Post subject: |
Had du adjust the B-pillar and make it straight, pressed the pillars togeter 1,8cm.
Hopefully this will do until I change to the new bulkhead.
[img]https://www.thesamba.com/vw/gallery/pix/1666150.jpg/img] _________________ Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
Bendango Samba Member
Posted: Thu Nov 06, 2014 10:20 am Post subject: |
Love this thread! - Keep it posted - due to the paint and the resurrection its one of those busses that pop in my head while I go about my day
AWSOME! _________________ I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote: |
Where did you find the elephant dick? |
vdouglu Samba Member
Posted: Thu Nov 06, 2014 10:51 pm Post subject: |
Great work! Looking good and a super cool bus! Keep it up. |
Niels - AirMighty.com Samba Member
Joined: September 05, 2004 Posts: 1666 Location: Amersfoort, the Netherlands
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Fri Nov 07, 2014 7:18 am Post subject: |
Superb work _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Posted: Sun Nov 16, 2014 9:43 am Post subject: |
More straightening, was 10mm wrong.
Posted: Sat Jan 24, 2015 9:58 am Post subject: |
Had to force the c-pillar down to get it straight
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sun Jan 25, 2015 5:00 pm Post subject: |
Outstanding work _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
