thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
Posted: Fri Sep 12, 2014 4:19 pm Post subject: Dropped spring plates fest |
Trying to figure how low of a dropped spring plate I want to order. Ive seen plenty of cars with the rear stance im after, but its always by the traditional, readjustment of the torsions. So post pics of your cars on dropped spring plates, from mild to wild! And let us know how much it's dropped. _________________ ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold |
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Fri Sep 12, 2014 5:36 pm Post subject: |
4" drop plates
No engine
195/60/15 rear tires
Deluxe Lowlight Ghia Samba Member
Posted: Sun Sep 14, 2014 8:45 pm Post subject: |
my old 64 4.5 inch dublab plates set at 8 degrees with 67 long axles
_________________ These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
59 patina ghia
61 patina Ghia
71 bus
73 super beetle
74 thing
75 half bug |
2-lo Samba Member
Posted: Mon Sep 15, 2014 1:22 pm Post subject: |
The dub lab 4.5" drop plates
I'm planning using Delrin bushings and modified Monroe 5752 shocks that I have added a bump stops to, I will be fitting them in a week or 2 so I will see how they ride.
This is the height im aiming for, Ive only driven the car once as there's still some things to do but at the high below the OE shocks are completely bottom out and there is a lot of Toe in.
[email protected] Banned
Posted: Tue Sep 16, 2014 5:34 pm Post subject: |
Atomwerk 3.6" Drop Plates, indexed at 20°
Atomwerk 2.4" Drop Plates, indexed at 21°
Atomwerk 2.4" Drop Plates, indexed at 17°
Atomwerk 2.4" Drop Plates, indexed at 20°
All these photos were of cars with stock torsion bars and all have zero toe in. |
Ace Samba Member
Posted: Tue Sep 16, 2014 8:09 pm Post subject: |
[email protected] wrote: |
They have toe in. They only wouldn't have toe in if you welded the springplates down so they wouldn't move. |
Posted: Tue Sep 16, 2014 8:20 pm Post subject: |
Ace wrote: |
Thanks Charles! I think I'm going 1.5 or 2 inch. With a 2332, berg 5, and recapped slicks I want it lower out back than stock, but with as little negative camber as possible. _________________ ITMC-El Presidente
Posted: Tue Sep 16, 2014 8:54 pm Post subject: |
Ace wrote: |
Ace, these plates have ZERO TOE IN at steady state rest, just like any other swing axle VW out there. What you are referring to is bump toe in (commonly referred to as "bump steer") - let's not get confused again...
Last edited by [email protected] on Tue Sep 16, 2014 8:57 pm; edited 1 time in total |
Posted: Tue Sep 16, 2014 8:55 pm Post subject: |
thebucket wrote: |
Ace wrote: |
Thanks Charles! I think I'm going 1.5 or 2 inch. With a 2332, berg 5, and recapped slicks I want it lower out back than stock, but with as little negative camber as possible. |
I would recommend that if you do not want too much camber. |
Ace Samba Member
Posted: Tue Sep 16, 2014 9:01 pm Post subject: |
Ace wrote: |
Ace, these plates have ZERO TOE IN at steady state rest, just like any other swing axle VW out there. What you are referring to is bump toe in - let's not get confused again... |
Let's also keep in mind that suspension is a dynamic thing. You can have 30 degrees of toe in at a "steady state rest" and that won't make a difference compared to "ZERO TOE IN" other than cosmetic. Bumps are a fact of life in a car that is driven.
That being said, here is mine with 2.75"
Posted: Tue Sep 16, 2014 9:06 pm Post subject: |
Ace wrote: |
With an Atomwerk plate there room to adjust to "0°" of toe in at rest - not 30°. I can't speak for anyone else's plates. Also it should be noted that toe in is not "cosmetic". It is an angle, and an angle that leads to dangerous handling unless it is zeroed out. |
Posted: Tue Sep 16, 2014 10:52 pm Post subject: |
thebucket wrote: |
Ace wrote: |
Cool! Let's keep posting pics with specs. I didn't post this thread for debates. Just a "fest" thread. _________________ ITMC-El Presidente
Posted: Tue Sep 30, 2014 7:41 pm Post subject: |
We also make drop plates for the IRS crowd (FYI we are the only manufacturers in the US who do so). Here are some pictures of Bill Hatfield's world record holding bug with our Racing Adjustable 2" IRS Drop Plates installed. He is making world records on our plates and he trusts his life with them!
2-lo Samba Member
Posted: Tue Oct 14, 2014 3:19 pm Post subject: |
4.5" thedublab plate's at 12 degrees
Looks very close to 2 outers with notched plates, I may go up a little to gain some travel but I need to finish some other things before it goes back on the ground then I can assess the way it sits properly.
volksgroove Samba Member
Joined: October 19, 2010 Posts: 239 Location: Apopka, FL
Posted: Sat Jan 28, 2017 2:04 pm Post subject: Re: Dropped spring plates fest |
I am making 3" and 4.5" drop plates again. There are a couple pics on the ad:
http://www.thesamba.com/vw/classifieds/detail.php?id=2016870 _________________ 1969 Riviera "Ethel"
1965 beetle father/son build
1988 Scirocco 16v father/son build |
