Damian Gomez Samba Member
Joined: September 17, 2013 Posts: 246 Location: Turlock Ca.
Posted: Thu Oct 16, 2014 10:02 pm Post subject: Finally getting to the big bore build |
My plan is 010 dizzy 1.1.1 rockers, and big bore p&c, plus a bigger jet in the 28 PICT CARB and new gaskets, I do not want to split the case as the motor ran fine before I pulled it. Will all this be just fine? Also, a piece of the fuel pump spacer broke and fell into the case, I can try to get it with tweasers but was told that the motor will just chew it up and I'll just have to change my oil and it will be fine, _________________ 63' beetle, stock 1200cc, 12v, daily driver but a project |
mahan Samba Member
Posted: Fri Oct 17, 2014 9:11 am Post subject: |
Pull it out with tweezers, it could scratch the bearing journals.
good luck |
Posted: Fri Oct 17, 2014 8:52 pm Post subject: |
it kinda just fell deep inside lol tweasers didn't work, well see what happens lol but the tin over the 1 2 cylinders seems impossible to get off no matter how hard I try, any ideas? _________________ 63' beetle, stock 1200cc, 12v, daily driver but a project |
mark tucker Samba Member
Posted: Fri Oct 17, 2014 9:23 pm Post subject: |
pull oil pump you may be able to get to it from there. |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
Posted: Fri Oct 17, 2014 9:28 pm Post subject: pump |
No, cam gear blocks it. Go thru the oil drain plate. |
mahan Samba Member
Posted: Fri Oct 17, 2014 9:36 pm Post subject: |
For the tin rap on it with a hammer, then put some liquid wrench oil on it and use a vice grip to turn the screws. Just get the vice grip as tight on it as u can and it should come off! Cheers |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Fri Oct 17, 2014 11:13 pm Post subject: |
vwhavermahan wrote: |
Heat it up. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Oct 18, 2014 4:13 am Post subject: |
Make sure you are aware of the potential clearance issues with #3. There's a few posts about this
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...mp;start=0 _________________ D-Dubya Manx clone - 63 Short pan,1914.
