kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Sat Oct 18, 2014 7:51 am Post subject: Need Some Turn Signal Advice |
My "new" '70 Baja has no front turn signals, and those '40 Ford type tail lights which I'm guessing won't also function as turn signals (I'm an electrical moron)? I'd like to use something on both fenders that will easily attach through the fiberglass fenders. Will stock units work? Do they have bolts that extend through the fenders, or threaded "female" receivers? Will stock units on the rear work on this ass...is it low enough to make them visible?
_________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
Dale M. Samba Member
Posted: Sat Oct 18, 2014 8:21 am Post subject: |
"Technostalgia" has a Ford Teardrop LED tail lamp system that will function as stop and turn signals...
http://www.cool-leds.com/6020_38-39ford.pdf
Another option is to add relay system....
Another option is Motorcycle Module..
http://www.signaldynamics.com/tri-star-turn-signal-to-brake-light-conversion-module/
Or last choice would be a conversion module to trailer (usually poorest quality of all the above)
Different turn signal switch may also be option, some after market unites will control turn signal/brake lamp functions correctly...
But suggest you do not get Chinese Chrome Plastic unit...
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Sat Oct 18, 2014 8:20 pm Post subject: |
http://www.cool-leds.com/vw.htm
