wellcraft Samba Member
Joined: September 12, 2014 Posts: 647 Location: Georgia
Posted: Tue Oct 21, 2014 4:10 pm Post subject: |
Bruce wrote: |
wellcraft wrote: |
Is this the gasket set I need to replace the rear axle tube retainer gaskets and o-rings, I noticed there is a bunch of gaskets and I did a quick search and it looks I need to put several of them. How would I know how many I need to put back?
Not sure if this a gasket set for the whole transmission.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-398-005 |
That set will get you some of the gaskets you need, but not all. Between the axle tube flanges and the side covers, you have O-rings. That kit doesn't give you this o-ring. |
I see the big one there but I wonder if is in this set im ordering too http://www2.cip1.com/ProductDetails.asp?ProductCode=C24-111-598-051-A |
Posted: Tue Oct 21, 2014 4:29 pm Post subject: |
Bruce wrote: |
wellcraft wrote: |
Tell Rancho you have O-ring flanges on your axle tubes, and ask them to include the right o-rings and the paper gaskets to set the freeplay. |
Will do that. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Tue Oct 21, 2014 4:36 pm Post subject: |
It's not in that kit either. But you'll need this outer axle bearing seal kit (x2). Ask Rancho for that kit too. Get 4 of them so you have some spares. _________________
Posted: Tue Oct 21, 2014 4:41 pm Post subject: |
Bruce wrote: |
It's not in that kit either. But you'll need this outer axle bearing seal kit (x2). Ask Rancho for that kit too. Get 4 of them so you have some spares. |
So u are talking about 2 different seal kits, now im lost ?
Do u have a part number of a kit so I can see what you are talking about, I'm a bit lost. I was looking at the parts and gaskets when I removed everything and cant find that o-ring, don't know if there is something different been this car is a 1999 model. |
Posted: Tue Oct 21, 2014 4:46 pm Post subject: |
Shoot, i'm slow today.
Ok, you are talking about the seal kit I posted (the outer one from the bearing side) im replacing the bearings too,BTW, plus the seal kit from inner side, right?
Which one u said I should ask for extra seals or gaskets, the inner seal kit with o-rings? |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Tue Oct 21, 2014 5:12 pm Post subject: |
wellcraft wrote: |
Driving that distance (500 miles in one day) could affect my engine due to higher rpm's for such a long drive/time? This worries me a bit as I don't know if the engine can handle it. I would assume yes but since I never owned a beetle I just prefer to ask. |
Unless your engine has been trashed and/or modified by someone using the internet for engineering guidance ( ) there is no reason it can't do everything it could do when new.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
jsturtlebuggy Samba Member
Posted: Tue Oct 21, 2014 5:18 pm Post subject: |
Besides a .82 4th gear there are .77 and .70 ratio available in the aftermarket. And I thing Gene Berg was selling a .68 4th gear.
They would work to lower the RPMs at the speeds you want to travel with the R&P you have. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Tue Oct 21, 2014 6:01 pm Post subject: |
Bruce wrote: |
Found this diagram and I only see the paper gaskets and the big o-ring https://www.thesamba.com/vw/gallery/pix/972663.jpg |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15280 Location: Deep in the 405
Posted: Tue Oct 21, 2014 6:16 pm Post subject: |
With a 1600 you DO NOT want a 4.12 with .82 4th gear. You do not have enough HP to turn it and the gap between 3rd & 4th won't be any fun to drive on city streets. Stick with the stock .89 4th gear.
A stock 1600 with a 4.12 R&P gear and a stock .89 4th gear using stock size tires will run 75 MPH for your 8 hour trips. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Tue Oct 21, 2014 6:20 pm Post subject: |
vwracerdave wrote: |
A stock 1600 with a 4.12 R&P gear and a stock .89 4th gear using stock size tires will run 75 MPH for your 8 hour trips. |
Thanks for the input, per Bruce suggestion I decided to go the exact way you are suggesting.
Thanks again for the help guys, if it wasn't for your help, probably I would be going 3.88. That its why I love the forums. |
