Keithinky Samba Member
Joined: June 13, 2014 Posts: 435 Location: Bradenton, FL
Posted: Mon Oct 20, 2014 3:04 pm Post subject: Engine bay- what am I missing?? |
Been cleaning the engine bay and realized I had a few "holes". I've probably looked at it a thousand times. I'm not too quick on the uptake
Could someone tell me the part name I'm missing. Or what I might need to do to the engine. Thanks.
Keith
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Oct 20, 2014 3:34 pm Post subject: |
I shouldn't be helping you, because you have a 1970 Convertible, so I'm jealous. Engine looks pretty nice. You have an aftermarket oil filler, so the vent tube which exits next to the dipstick is not there, maybe plug that hole with a rubber stopper.
I wonder if the 1970 ever had dealer-added AC, might explain the two firewall holes. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Brian Samba Moderator
Posted: Mon Oct 20, 2014 3:57 pm Post subject: |
Measure the size of that pulley.
Also the hoses that are attached to the shroud, you're supposed to just take one and cut it in half for both sides. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
talljordan Samba Member
Joined: January 10, 2012 Posts: 967 Location: San Francisco, CA
Posted: Mon Oct 20, 2014 4:00 pm Post subject: |
I'm going to give advice on your bay in general, feel free to ignore it. I have no clue how much you know.
Your drivers side air hose is too long, you are losing air pressure because the air has to travel along that bend. I would recommend trimming it down to size.
You have an aftermarket alternator and alternator stand. This is why your oil fill hole doesn't have the stock downspout, leaving you with a tin hole.
You are missing your firewall insulation, not a necessary component, but it does reduce cabin noise.
You are running a 009 distributor, I would recommend a stock SVDA, as the 009 doesn't pair well with your 34PICT3 carb, you probably have a flat spot when taking off.
Your crank pulley is aftermarket. It looks like a SCAT brand one, I would check. SCAT is good, EMPI is shit. I run an aftermarket SCAT and really like it.
I would recommend getting rubber boots for your alternator connectors as well.
Overall the bay is pretty gorgeous and I am a little jealous, but I was bored and felt like knit picking... _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Mon Oct 20, 2014 4:21 pm Post subject: |
Guys- thanks. I will adjust air hose tomorrow. I will look into the SVDA dist tonight. Yes, when I pull out there is some hesitancy. I will look to plug the hole near dipstick. I will look tonight also to get rubber boots for alt as well.
I have considered firewall insulation. That's a maybe. When I was restoring inside I used peel and seal (quick roof equivalent)It really helped. Every little bit helps just not sure about adding the insulation right now.
I appreciate the suggestions.
Keith |
VW_Buggsy Samba Member
Posted: Mon Oct 20, 2014 6:53 pm Post subject: |
Re: air hoses
I actually don't cut mine in half and use them for two but rather buy a couple and trim them only enough to make a smooth bend and path to it's destination. Then if one gets damaged it's easier to just expand it more and cut out the bad end.
Just a different way of doing things. |
Posted: Tue Oct 21, 2014 8:29 am Post subject: |
Ok about the SVDA dist- is there a model or make you would suggest. I searched last night and quickly discovered there are many models with many options, the dist, with Hall effect…
I must admit- with regard to the technical, I am easily overwhelmed.
Thanks. |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 833 Location: Grand Forks, ND
Posted: Tue Oct 21, 2014 11:14 am Post subject: |
Those holes that you pointed out appear to be exactly where my Automatic Stickshift ATF hoses go through on the passenger side. And on the driver's side, it looks like the place where the vaccuum hose goes for the clutch servo motor. _________________ 1969 VW Beetle Convertible |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Oct 21, 2014 1:42 pm Post subject: |
I'd be tempted to agree your car was auto in a past life, only thing I notice is the large hole in the side of the engine bay where the ATF filler neck comes through isnt there and the control valve mounting bracket isnt there but maybe convertibles were different because of that corner bracing in the engine bay. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Tue Oct 21, 2014 2:33 pm Post subject: |
Keithinky wrote: |
Thanks. |
Post this as a new topic. Distributors are super confusing. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Tue Oct 21, 2014 2:36 pm Post subject: |
Post this as a new topic. Distributors are super confusing.[/quote]
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Tue Oct 21, 2014 6:49 pm Post subject: |
Joel wrote: |
I'd be tempted to agree your car was auto in a past life, only thing I notice is the large hole in the side of the engine bay where the ATF filler neck comes through isnt there and the control valve mounting bracket isnt there but maybe convertibles were different because of that corner bracing in the engine bay. |
I switched my convertible to 4 speed from auto stick and I can confirm the control valve bracket and ATF filler hole are there, same as on a hard top. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Tue Oct 21, 2014 7:12 pm Post subject: |
Wow-ok, autostick. So this adds a little more mystery to its history |
