herkster Samba Member
Joined: February 14, 2013 Posts: 428 Location: Boca Raton, FL
Posted: Sat May 03, 2014 3:10 pm Post subject: |
We have a full wheelbase buggy with a stiffy bar and a 200 hp 2.5 liter NA Subaru. It's not done yet but we expect good things. Lots of rubber with dropped atom plates in the rear and a dropped and narrowed 4 inch front. No sway bArs yet until we figure it out... |
eschmi Samba Member
Posted: Fri May 09, 2014 5:09 pm Post subject: |
Glenn wrote: |
A 1956 engine is 36hp.
Slow is a relative term.
A 1600 would be a nice upgrade. |
I was told there were a few "industrial" 25hp motors made in 1956, still havent been able to get a solid answer on that either, the Vin says it was made in early 1956, but as another person told me a 36hp will have little raised triangles on the tins right above the spark plugs which mine do not so i'm a little confused... We do have about 4-5 old beetles and 2 old buses laying around at my uncles so I might go check out and see if theres any bigger engines around, since i'm essentially rebuilding EVERYTHINGGG, frame, engine, fixing/repainting the body... might be worth a look... just dont want it to be annoyingly slow... ya know? Heres a few pictures of the engine.
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Sat May 10, 2014 7:37 pm Post subject: |
Sell that antique to someone looking for a period correct motor and go get a 1600cc dual port at a dead MINIMUM. You'll be glad you did. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
eschmi Samba Member
Posted: Sat May 10, 2014 8:21 pm Post subject: |
Lo Cash John wrote: |
Sell that antique to someone looking for a period correct motor and go get a 1600cc dual port at a dead MINIMUM. You'll be glad you did. |
Problem is it doesn't run or anything, and I'm still not sure if its a 25hp or 36hp :S but that is what I was thinking... selling or trading it for a 1600 or something that might be a little more zippy. Thats the other thing I was unsure of is if this would be enough for just zipping around town and maybe some highway between towns like 60-70ish tops or if it would take a decade to get to merging speed on the highway. |
manxcraig Samba Member
Joined: November 12, 2006 Posts: 617 Location: pendelton (indianapolis) indiana
Posted: Sun May 11, 2014 7:31 pm Post subject: |
Listen to John, someone will be glad to trade you for a good 1600. You ask if that engine would be painfully slow getting up to freeway speeds? Don't worry, it will NEVER get to freeway speeds! My old 40 horse would run faster in third gear than it would in fourth, so a 25 or 36 would be worse.
Again, a 1600 dual port engine MINIMUM. _________________ 69 Meyers Manx II on 65 pan, 1 owner !
WANTED, Meyers Manx license plate frames, repo OK, don't like the new smiles per miles ones. |
eschmi Samba Member
Posted: Sun May 11, 2014 8:22 pm Post subject: |
Yea, i've been strongly considering it... we actually went over to my grandmas today to rummage around some of the old parts because we use to have 5 old beetles and 2 buses there... well I happened to find a bunch of old pistons, 4 old carbs, bunch of old light housings and misc parts but the best find is 1 engine that I can't identify because its missing too much and the serial is gone, a 2nd engine that is a 65 40hp that seems to be in decent shape, and 2, 12v generators! so now I need to decide what to do with myself and all this extra stuff. The generators I'm keeping, 1 for an engine, and another we're going to use for a small wind turbine, engines i'm not sure yet. Also this is kind of a noob question... but would a 1600 or bigger engine work on the current transmission and everything or would I have to swap it all out? the "frame" is from a 1960 beetle and the rest of it is from a 56 beetle... |
eschmi Samba Member
Posted: Tue Oct 21, 2014 7:11 pm Post subject: |
Well I got my hands on another engine out of a 73 bettle along with a new trans-axle to go along with it, so i'll be running a 1600cc dual port Oh and a friend of my dads apparently use to have a buggy and decided to sell it before they rebuilt it, but they still have the whole little rebuild kit for it, 1600cc big bore kit to boot! this things going to sprout wings and fly! |
EVfun Samba Member
Posted: Tue Oct 21, 2014 7:21 pm Post subject: |
The '73 transaxle isn't going to fit. The front mount is different it has a double jointed rear suspension in place of the single joint swing axle transaxle. That is O.K. because you can run the 1600 on the older transaxle, there are a couple of ways to do it. You will need a new clutch pressure plate at a minimum. _________________
Wildthings wrote: |
Posted: Tue Oct 21, 2014 7:33 pm Post subject: |
Good to know you're still at it!! A stock 1600 in a buggy will be awesome. It'll require low maintenance and have plenty of pep too.
That spare transmission is not easily swapped into an early chassis like yours BUT you can always sell it and apply the profits to the buggy. _________________ www.LoCashRacing.org
slalombuggy Samba Member
Posted: Tue Oct 21, 2014 7:40 pm Post subject: |
I would try and find another transaxle if the one you have in your buggy is split down the middle and bolted together like the engine case. They are a very weak transmission and will not withstand any abuse. To put the 1600 in the early split transaxle you have to clearance the bellhousing for the larger 1600 12V flywheel, and the starter bushing will need to be changed to the 6-12V adapter bushing.
Everyone asssumes 36ers are gutless pieces of poop. I've had the pleasure to drive a couple that have been truely rebuilt and a couple others that have ben hotrodded at Bonneville and they are a pretty peppy engine for their size. Even in a bus a well built 36 is surprising. I've driven a few older 36hp cars and the difference between an old 36 engien and a fresh rebuild is night and day Most guys were running high 60s to mid 70mph in the standing mile is all sorts of vehicles with stock engines. Tom Newport hit just over 100mph in his buggy with a modified 36hp motor this year.
brad |
eschmi Samba Member
Posted: Tue Oct 21, 2014 8:00 pm Post subject: |
the pan is a 1960, the original tranny was with the original engine which ended up being a 1956, the new transaxle is newer, i'll have to double check to make sure but I believe its a 65 or 67, I would have taken the transaxle off the 73 in a heartbeat but we noticed that the little bars, torsion bars? coming out the back were Very short and very different from the ones on my pan and the transaxle mounted different up front (looked that way anyways) so we grabbed another one off a different beetle that use to be my dads old beetle he rebuild when he was a kid, so I'm hoping it will hold up... bigger issue right now is getting the pan fixed... here's what I'm dealing with... http://imgur.com/a/l0Jfe I thought they took 2 pieces of metal and just crappily welded around them... turns out its almost an inch thick of slag.... ground it down as best I could but that stuff just chews through wheels, luckily a friend of mine is a weld inspector for the nuclear plants in the area so he's going to help me out n weld it up and make sure its strong... would just grab a new pan and chop it up but this ones already stripped down to nothing so yeah... just need to get it welded n blasted before the snow hits! |
eschmi Samba Member
Posted: Tue Oct 21, 2014 8:02 pm Post subject: |
Oh, did I mention the last bunch of pics are spare engines and brand new-old parts and a crap ton of wheels caps? Going to use some of those to help fund fixing the botched fiberglass body... also any idea what the V logo is on some of those caps? looked all over google and even on here and got zilch. |
EVfun Samba Member
Posted: Tue Oct 21, 2014 8:48 pm Post subject: |
Looks like some previous owner has already handled the transaxle swap to the later tunnel type transaxle. You should be able to run any 1961 to 1968 transaxle, but you may have to put the nose cone from the transaxle in the buggy onto any replacement. They could have swapped to the later transaxle by using a older Bus nosecone, or by changing the mount on the frame. _________________
Wildthings wrote: |
eschmi Samba Member
Posted: Tue Oct 21, 2014 10:21 pm Post subject: |
Thanks for the advice, the new engine and tranny are still sitting in the van at the moment, going to move them to the basement tomorrow and see how it lines up, worst comes to worse theres 4 other transaxles sitting at my uncles along with enough parts to make a few cars haha |
eschmi Samba Member
Posted: Wed Oct 22, 2014 5:02 pm Post subject: |
Update: I double checked the transaxle because I was worried it might be a split and be junk... luckily it's not, both are solid and not bolted together and the "new" transaxle is a 58. |
joescoolcustoms Samba Member
Posted: Wed Oct 22, 2014 8:57 pm Post subject: |
'58 was a split case transaxle. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
eschmi Samba Member
Posted: Thu Oct 23, 2014 12:09 am Post subject: |
When you say split case you mean like the whole thing splits right down the center into two pieces right? I'll have to look again -facedesk- it's my dads old beetle and he claims its a 58, but I guess i'll have to look up the serial but it doesnt split down the center. |
Posted: Thu Oct 23, 2014 6:13 am Post subject: |
The split case transaxles were used into model year 1960. But, as old as VW's are, they can easily have been changed years ago.
The split case splits into two pieces with the seam on the top and bottom, just like the engine.
here is a split case:
here is the later tunnel case transaxle:
You can see the split lines and bolts on the top two pictures of where the case goes together. The later transaxles are considered one piece cases even though the side covers come off. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
eschmi Samba Member
Posted: Thu Oct 23, 2014 11:37 am Post subject: |
Thanks for the explanation, sorry I'm a bit of a noob, just triple checked it, I thought it was split for a minute... almost crapped my pants. But there's no bolts going through at all and followed what looked like a seam up to the bell housing and there was no seam on the top/inside of it, and cleaned off and checked the serial just to be certain. 8220403 so that should put it at a lat 63. So i should be in the clear lol as long as this one doesn't drain metal shavings in the oil like the other one did! |
eschmi Samba Member
Posted: Sun Nov 16, 2014 11:14 pm Post subject: |
That spare transmission is not easily swapped into an early chassis like yours BUT you can always sell it and apply the profits to the buggy. |
So question... if a family friend has a rebuild kit for a 1600cc engine and wants $200 for it would I be stupid not to pick it up? Has 85.5mm pistons and heads, gaskets for the engine, push rods, tubes, the works. Did some research and all i've been able to find says that theres no way of telling if it will work unless you actually have the engine completely torn apart, but I haven't even gotten to that yet because I've been working on the pan... Thoughts? |
