Robbo112233 Samba Member
Joined: September 18, 2011 Posts: 817 Location: London, UK
spencerbai13 Samba Member
Joined: December 05, 2011 Posts: 70 Location: United States
Posted: Fri Oct 03, 2014 7:53 am Post subject: |
Robbo112233 wrote: |
Looks nice man, What adjusment did you make to the back? |
Just 2 inner splines. I didn't want to be riding on my bump stops and i don't really have anywhere in my apartment where I could notch the spring plates so I didn't go too crazy in the back. |
Posted: Fri Oct 03, 2014 8:01 am Post subject: |
spencerbai13 wrote: |
I think it looks spot on, i think i will go with 2 inners.
Give it a nice tuck _________________ 1973 Bug
Beetle Bums VW Club member
Archie's Photo Gallery |
Posted: Fri Oct 03, 2014 10:12 am Post subject: |
Give it a nice tuck |
Thanks man I really appreciate it. I was creeping through your topics to see what your bug looked like, and I think it's the only bug I've ever liked on 8 spokes. Looks really clean! |
Posted: Mon Oct 06, 2014 9:12 am Post subject: |
Cheers, a lot has changed since them photos! I will be putting up a update soon.
Keep up the good work! _________________ 1973 Bug
Posted: Thu Oct 09, 2014 6:26 pm Post subject: |
So I've been contemplating on what to do for the rear in regards to air, and I think I figured it out. I was going to buy the rear airkewld kit thats $500~ or so but I think I'm just going to fab it up myself, and get someone to weld it for me.
Im basically just going to copy this basic design
The front I'm keeping simple and pulling the adjusters out and using air shocks. Im not sure how long it'll be before I start doing the air in the rear, but hopefully i can get the front done, along with a tank and compressor around the new year. |
MattFillups Samba Member
Joined: September 02, 2014 Posts: 6 Location: Orlando, FL
Posted: Fri Oct 10, 2014 1:43 pm Post subject: |
Nice! Looking forward to seeing this thing slammed! |
Posted: Wed Oct 22, 2014 11:40 am Post subject: |
Got some time to mess with the bug, so I decided to adjust the valves, which I've never done on this motor. Turns out all the valves except for the ones on cylinder 1 were a little tight, so good thing I did that. I also checked my points gap and drove it around for a bit. Ill start collecting parts for the air ride build here in a few months, maybe I can get a few bits I need for Christmas |
Posted: Wed Dec 10, 2014 11:29 am Post subject: |
So parts are starting to come in for the air ride system! My amazing parents are getting me most of what I need for bags for Christmas. I'll document everything because I know a lot of people who want to run air on their bugs don't because there isn't a ton of info on what to do if you don't run a premade kit like from airkewld.
Heres the parts Im going with
Compressor: Viair 444c single. $150
Chose this because of the low price, high psi ratings and high duty cycle ratings.
Tank: No Name 8 port 3 gallon ebay tank. $60
Rated up to 200 psi which is as high as my system will ever go. 3 gallons because I didn't want it to take up too much space but I wanted a little bit of size so I could play around with the ride height a bit
Front: Monroe MA756 $60.
Chose this because it's what everyone says to run on balljoint beams. I will be making the fitting on it 1/4" though. I might have to grind off part of a trailing arm but I'll do that when I get to putting them on.
Switch: Generic 120 on 150 off switch off ebay. $20
150 should be plenty, but I can always return it and get something with higher psi ratings.
"Management System": 4 manual paddle valves off ebay. $80
I put this in quotes because it's really just simple paddle valves. 1/4" barbs on them, and I went manual just so theres no more strain on the electrical system, and because its cheaper.
I think I've decided what to do for the rear as well. Im gonna use slam specialities ss-5 bags with these style mounts.
I will be buying new trailing arms this week so I can weld a bag mount into them and then just swap them when I pull the engine/tranny to do the upper bag mount.
Im gonna mount the tank on the parcel shelf, and run hardlines down into a false floor and then 1/4" soft lines everywhere else to keep it cheap. |
webberjames95 Snorkelstang Finder
Joined: January 18, 2011 Posts: 1091 Location: Pullman, Washington
Posted: Wed Dec 10, 2014 12:42 pm Post subject: |
webberjames95 wrote: |
doing all this work to your bug in the parking lot of the Grove. lol love it |
How do you know i'm at the grove? I need to make sure the bug is locked haha just kidding |
Posted: Wed Dec 10, 2014 1:07 pm Post subject: |
We have one at my university. Looks the same _________________ 1967 Bug:
Olga: the Cal look car lost in the PNW SOLD
1984 Vanagon:
Berty the Vanagon
1973 Bus
Amber the Bus Sold
INSTAGRAM @jwebber95 |
Posted: Thu Dec 11, 2014 10:50 am Post subject: |
We have one at my university. Looks the same |
ahhh makes sense now. Yea I'm pretty sure the grove wants me to leave by now. |
Posted: Thu Dec 11, 2014 2:00 pm Post subject: |
Today I bought a generic amp installation kit off ebay, Just for the fuse holder and 8 gauge wire.
I also have a viair 40 amp relay in the mail, as well as some 1/2" npt to 3/8" npt reducers for the bags I decided.
I decided on some I found from a dealer local, that are Dominator II 2500.
They are 2.8" compressed, 10.5" extended, and a 6.25" diameter. These specs seem good and the cost is only $65 each.
I got a reducer because they have a 1/2" npt port on the top.
I also drew up a basic wiring/air line diagram just to make sure I'm not forgetting anything.
Here is everything else I need to finish
4 1/4” ptc
2 7/17-29 1/4” ptc
6 3/8” npc 1/4” ptc
4 1/4” bulkhead ptc
4 gauge 1/4” ptc
2 1/2”-3/8” reducer npc
2 dual needle gauge
1 1/4” plug npc
1/4” copper tubing
1/4” air line
2 Dominator II 2500 air bags
Rear bag mounts (Found some I need on ebay) _________________ Bagged 1970 build: http://www.thesamba.com/vw/forum/viewtopic.php?t=606237 |
zodlaw Samba Member
Joined: July 27, 2005 Posts: 507 Location: Battle Ground, Wa.
Posted: Mon Jan 19, 2015 3:08 pm Post subject: |
zodlaw wrote: |
Did you flip your tie rods? |
Nope. I'm bolting on the air ride soon so I'm hoping it won't really be necessary since most of the driving will be done aired up a bit. But as it sits the tie rods don't hit anything. _________________ Bagged 1970 build: http://www.thesamba.com/vw/forum/viewtopic.php?t=606237 |
Posted: Wed Jan 28, 2015 10:04 pm Post subject: |
Since my last post I've gotten a few things done. Pressed out the bushings on the air shocks, put in the ones from some bug shocks, and also covered the panel holding the compressor and tank in black vinyl, since I'll be redoing the interior in that.
I also got the air shocks mounted, as well as the parcel tray shelf and I wired everything up today. They work! I'm so excited. Pulled my grub screws and it goes from on the ground to basically stock height!
Heres a video of it airing out.
https://www.youtube.com/watch?v=_eZkgpxqqyg&feature=youtu.be _________________ Bagged 1970 build: http://www.thesamba.com/vw/forum/viewtopic.php?t=606237 |
eguti66 Samba Member
Joined: July 21, 2004 Posts: 260 Location: Stockton,CA
Posted: Thu Jan 29, 2015 9:35 pm Post subject: |
Nice work so far on your air ride setup, I may copy your setup. What mounting kit did you use for the rear? you mentioned it was from ebay _________________
drscope wrote: |
Ummmm, if you can't find out where the hole is by feeling around, then FORGET about installing the light! |
66 beetle
65 karmann ghia
58 beetle
58 convertible beetle
64 11w standard
68 Squareback |
