Randy in Maine Samba Member
Posted: Wed Oct 22, 2014 4:52 pm Post subject: |
You know that they are under-rated car tires don't you? |
kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Tue Nov 04, 2014 6:28 pm Post subject: |
If your talking about my 530300, please be more specific. From the samba forums it does meet what is need for weight, speed and tire pressure specs. Also, important to note, JEGS, summit etc. don't correctly rate the tires. You need to look at the coker tire site.
If I am wrong, please point out the specific issue, I actually would appreciate it. _________________ 84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Nov 04, 2014 7:55 pm Post subject: |
kjono09 wrote: |
From Coker Site: https://www.cokertire.com/p205-75r14-coker-classic-2-3-8-whitewall.html
SKU: 530300
Tread Width: 5.68
Section Width: 8.14
Overall Diameter: 26.11
Load Index: 97
Speed Rating: P
Max Load Capacity: 1532@35PSI
Rim Width: 5.50 - 7.50
Tube Type or Tubeless: Tubeless
Since they are car tires, you have to de-value the 1532 by 9%. That yields 1394 Lbs / tire. I did not look it up to see if light or not; sounds a bit light. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Buss Marius Samba Member
Joined: February 29, 2012 Posts: 98 Location: Oslo, Norway
Posted: Sun Nov 09, 2014 4:53 pm Post subject: |
I think this is the product to use on the tyres:http://www.mbzponton.org/valueadded/other/tirepaint.htm
it is from Iceland. _________________ 87 75hp VW LT 28 Karmann LT L, 90 T3 Syncro 75hp AAZ Reimo Camper. 00 T4 102hp TDI Caravelle bus. |
