webkongen Samba Member
Posted: Thu Oct 23, 2014 2:19 pm Post subject: Building a 500hp type 1 engine |
Hi.
I am building an engine in Norway.
Its a 2332cc with turbo and intercooler, the set up is for 500hp.
In my Autolinea/rimco supercase i have all 411 mains.
My DPR 84mm crank has also all 411 main journals.
Where do i get the main bearings of best quality that fits this combo? |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Thu Oct 23, 2014 3:37 pm Post subject: |
I would get in touch with DPR and ask them. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Oct 23, 2014 3:39 pm Post subject: |
Silverline _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Oct 25, 2014 5:36 am Post subject: |
Buy several sets.... You will get used to changing them. Clevite77 rod bearings too... No matter the brand....500 hp will trash them frequently. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
Bad bug Samba Member
Posted: Sat Oct 25, 2014 5:46 am Post subject: Re: Building a 500hp type 1 engine |
webkongen wrote: |
Why didn't you leave the bearing saddles in the case stock and just go with the BMW bearing conversion. Those bearings are t1 outer and 411 inner steel back bearing.
For my engine i will be using a TF1 case with the BMW conversion. |
