kevlarian Samba Member
Joined: October 16, 2014 Posts: 636 Location: Orange County, CA
Posted: Thu Oct 23, 2014 10:26 am Post subject: Looking for... but can't find... INFO '68 disc brake |
So, I really want to convert my front brakes (1968 Bay) to Disc. There are a ton of conversion kits for nearly all makes and years, but I can't seem to find any for the 1968 Bay Type 2.
My Bug Mechanic said that the 71 Bay was the first to come with front Disc. He indicated that the front was nearly a direct replacement for my front. Has anyone done this mod, or does anyone have additional advice.
I have to say, my brakes SUCK ARSE! I am hoping the mechanic can tighten them up a bit, but otherwise, I would like to look at doing a front conversion.
Thanks!
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu Oct 23, 2014 11:14 am Post subject: |
Hi there,
I've never converted an early bay to disk brakes but have installed a power brake booster on a 1968. The brakes work way better. You cannot just swap the whole front beam from a 1971 to a 1968. They won't bolt together. You could swap out some of the other parts though but then you'd be left with wide five wheels in the back and the smaller five wheels in the front. I suggest you consider doing the booster mod instead. Not too hard and your bus will maintain its original look.
http://www.thesamba.com/vw/forum/viewtopic.php?t=511636&highlight=brakes _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Oct 23, 2014 11:34 am Post subject: |
Please edit your post title so that people have some clue about what it is you are looking for. You may find more help that way. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Brian Samba Moderator
Posted: Thu Oct 23, 2014 1:14 pm Post subject: |
wagenwest has some kits for early bays. there is a write up on it in the split window forum. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Egorspyle65 Samba Member
Joined: March 06, 2009 Posts: 249 Location: Easley SC
Posted: Thu Oct 23, 2014 3:57 pm Post subject: |
I have the wagenswest kit on the front of my 68 bay. Was on there when I bought it and has dropped spindle also. Good setup though and. Uses wilwood brake parts. It's the baby stang kit so you can run 14s if you want to. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Fri Oct 24, 2014 3:46 am Post subject: |
Quote: |
You cannot just swap the whole front beam from a 1971 to a 1968. They won't bolt together. |
Is this right? I moved put a 71 axle beam onto a 69 back in the 80s when the 69 rotted out. Is the 68 different? _________________ .ssS! |
Posted: Fri Oct 24, 2014 5:57 am Post subject: |
Yes it is _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
vwcanuck Samba Member
Joined: September 27, 2012 Posts: 155 Location: Canada
Posted: Fri Oct 24, 2014 6:11 am Post subject: |
That's a nice 68 you have kevlarian.
In another post you mentioned that the PO had rebuilt the brakes a couple of years ago ... and now they "suck arse" as you say. Are you sure that all of the other components, master cylinder, lines, brake cylinders, pads and star adjusters, are in top working condition and adjusted properly? It would be a shame to spend the time and money converting to discs up front and find that your master cylinder is pooched or that your star adjusters weren't adjusted properly.
The reason why I mention this is that I rebuilt my 68's brakes last year and they work awesome! I tried some emergency stops and I was impressed with how well the drum brakes on all four corners stopped the bus. I hope you go through the brake system on your bus and start with the easy stuff. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Fri Oct 24, 2014 7:39 am Post subject: |
I agree that the 4 non powered drum brakes aren't as great as a power disc brake set up, but I wouldn't says they "suck arse." Like posted above how's the condition of your brake system? I DD a 68' in the mountains of SW colorado with a big engine and and I don't have a problem with my brakes. I keep them well tuned and usually adjust them every 1500 miles or so. Maybe you need to adjust yours and put our foot into it when stopping. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Fri Oct 24, 2014 12:43 pm Post subject: Re: Looking for... but can't find... INFO '68 disc brake |
kevlarian wrote: |
There are a ton of conversion kits for nearly all makes and years, but I can't seem to find any for the 1968 Bay Type 2. |
http://www.wolfsburgwest.com/wolfsburg_new/brakes/bus_brake/disc_brake_CSP.cfm
richparker wrote: |
I agree that the 4 non powered drum brakes aren't as great as a power disc brake set up, but I wouldn't says they "suck arse." Like posted above how's the condition of your brake system? I DD a 68' in the mountains of SW colorado with a big engine and and I don't have a problem with my brakes. I keep them well tuned and usually adjust them every 1500 miles or so. Maybe you need to adjust yours and put our foot into it when stopping. |
I agree with this ^^^^^^^ _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
