slyness41bus Samba Member
Joined: October 20, 2013 Posts: 41 Location: Clackamas
Posted: Thu Oct 23, 2014 2:59 pm Post subject: shifter issues |
I have a 72 bus, took the shifter apart to regrease and clean up. ever since, it wont go into reverse, BARELY goes into 1st and 2nd. I have tried moving the plate around, it just gets WORSE.
Cant seem to find anything USEFUL in the other posts. it goes together well, no fight there, bushings are good. when I push down for reverse, it SEEMS to go inot reverse, but stays in 2nd-ish....
My manual is less than helpful also, it just says to put the shifter at 90 degrees in 2nd gear, and move the plate around. non specifics do not help, I need SOME info that deals with specifics.. |
Tcash Samba Member
Posted: Thu Oct 23, 2014 3:42 pm Post subject: |
Check your shift coupler and front bushing.
Shifter parts |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Thu Oct 23, 2014 3:52 pm Post subject: |
I have had the same thing happen to me a couple of times. The last time a car park popped it out. Only I cannot remember the "trick" to getting it back in place. You are right. The book is no help. _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
SGKent Samba Member
Posted: Thu Oct 23, 2014 4:08 pm Post subject: |
did you mark where the stop plate was before you began? The stop plate has to be adjusted right.
Did you do any other work at the same time and how far apart did you take the parts. Which pieces came apart? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Thu Oct 23, 2014 5:11 pm Post subject: |
So you definitely know that the forward shift rod bushing is good? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
aopisa Samba Member
Posted: Fri Oct 24, 2014 11:16 am Post subject: |
wihr wrote: |
You are right. The book is no help. |
Blasphemy! Everyone knows the Bentley contains every bit of information you will ever need in easy to find, concise and clear step by step instructions. It's word is gospel and not to be doubted. _________________ 1977 Westy 2.0L FI
Leap into the boundless and make it your home! ---Chuang-Tzu
Please let me know if you do not receive this message... |
Posted: Fri Oct 24, 2014 11:30 am Post subject: |
Found the problem, it was the coupler. I just reinstalled a brand new one in there and that cheesy bolt through the piece of bent metal they give you had failed.
so instead of using that ghetto set up they gave me with the new parts, I put in grade 8 bolt with a Nighlok threaded nut. Shoulda done that in the first place. A rolled piece of pot metal and a wood screw don't really strike me as being high tech.
Now it shifts perfectly nice and tight better than it ever has been actually since I installed that bolt, figures.... |
Posted: Fri Oct 24, 2014 11:35 am Post subject: |
Glad that you fingered it out _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Manfreds78bay Samba Member
Posted: Fri Oct 24, 2014 11:59 am Post subject: |
Had the same thing happen to me and found out my front grub screw was loose. The book adjustment is pretty right on. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
