corolla11 Samba Member
Joined: November 21, 2013 Posts: 11 Location: Malta EU
Posted: Sun Oct 05, 2014 4:30 am Post subject: Dimensions required |
Hi I am quite new to beetle's and I bought a big project, it's a rust package for a first restoration. Time will tell if I manage to finish my project and drive my 62 beetle. I would like some one to tell me the length from under the rear vents to the water channel in the engine compartment. I will try to post pictures later on.
Thanks |
grandpa pete Samba Member
Posted: Sun Oct 05, 2014 2:09 pm Post subject: Photo for reference |
Please note that I require the dimensions for the area marked with a red arrow. Thanks
carcrazed Samba Member
Posted: Sun Oct 05, 2014 3:41 pm Post subject: |
I measured on my 61. 7/8 of an inch. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Sun Oct 05, 2014 10:27 pm Post subject: |
Thanks Carcrazed for your help, i |
Posted: Sun Oct 05, 2014 10:56 pm Post subject: |
Hi Guys, i managed to upload some photos of my car.
till now i managed to remove all the body panels, restored decklid and passengers side bumper bracket.
Now i am in the process of repairing the rear screen area, which really needs alot of work. wish me luck
[img][/img]
[img]
[/img]
[img]
[/img] |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Mon Oct 06, 2014 8:02 pm Post subject: |
Doesn't look bad to me!! |
Posted: Thu Oct 23, 2014 9:20 pm Post subject: |
Does any one know the best way to repair the rust seen in above picture, just behind the rear lovers and vents ??
And please share your comments . |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Thu Oct 23, 2014 9:47 pm Post subject: |
If you mean forward of the vents. Would remove the sheet metal inside the rear of the Beetle below the window and clean it all out in there. _________________ In Stereo, Where Available! |
Posted: Fri Oct 24, 2014 5:28 am Post subject: |
Would it be the best solution to cut the marked area and use a new built part?
[img][/img] |
Posted: Fri Oct 24, 2014 6:45 am Post subject: |
Better to open it up more so you can easily get out all of the rust inside. Then a good zinc primer, weld back together and zinc primer over the welds.
Plus the top cut line you have now is going to show the weld bead thru the vents too easily. _________________ In Stereo, Where Available! |
