ClareSutton Samba Member
Joined: December 05, 2004 Posts: 466 Location: Sarnia Ontario
Posted: Fri Oct 24, 2014 6:06 am Post subject: Frame Head Bottom Cover Plate |
The frame head bottom cover plate on my '73 standard beetle is badly rusted out in the center. I want to replace it and have ordered a new one. I read everything that I could find in the search forum to get an idea as how to replace it. Most of the information says to remove the old one and weld in the new one. I am no welder and I don't even have the equipment. If the old plate is only rusted out in the center could I not just clean it up and pop rivet the new one on top? I could grind down areas to make it fit properly and maintain the strength from the old plate and use the new plate as protection for the old plate and the exposed tunnel. Would that be so bad? |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Fri Oct 24, 2014 6:17 am Post subject: |
That is a structural part - holding and aligning the front suspension on. Pop riveting is not a structural repair. If rusted thru hole is larger than a couple inches the current spot welds need to be ground off, rusted plated removed and a qualified welder weld a new plate on maintaining correct alignment while grinding off old and welding new. Where there is a small amount of rust - cleaning the area will usually reveal far greater damage. You could sand blast area and if not too bad - treat with POR-15 BUT if it too bad it makes it dangerous to drive. Post picture (with reference item) if uncertain. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Fri Oct 24, 2014 7:07 am Post subject: |
Here is some pictures. Would welding the new plate over top of the old one work? That way the alignment would be maintained. |
beetlenut Samba Member
Posted: Fri Oct 24, 2014 7:54 am Post subject: |
Best to remove the old plate entirely and get a good look at how bad it really is. Not an area of the car you want to skimp on when it comes to repair. You might find when you get into it, that you have to replace the entire frame head. No way to tell until you get it taken apart. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Fri Oct 24, 2014 9:13 am Post subject: |
As long as you don't remove any of the frame head where the beam bolts on, you will not affect the alignment.
I also would remove all of the old bits and repair it correctly. Hard to tell from the pictures but I see what look like a couple of welds in places the factory didn't put them. It just doesn't look right. Could have already been patched up.
I have done this repair before, but only on a bare chassis. With the gas tank and front suspension removed it can probably be done with the body on but I have no idea how difficult it would be to reach everywhere you need to get it cleaned and welded up properly. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri Nov 14, 2014 11:22 am Post subject: Frame Head Bottom Cover Plate |
Repaired by Sarnia Welding Company. Looks good to me.
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Nov 14, 2014 12:10 pm Post subject: |
wait a second... did they weld the plate to the torsion tube? _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Fri Nov 14, 2014 12:52 pm Post subject: |
GArBa wrote: |
wait a second... did they weld the plate to the torsion tube? |
Looks. like it to me... no changing that out with out a lot of work _________________ 66- Ghia
76-Beetle |
Posted: Fri Nov 14, 2014 2:31 pm Post subject: |
Yikes!! Any pictures I have seen look like there are welds attached to the torsion tube. Is this a problem? The car drives and handles well. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Nov 14, 2014 3:19 pm Post subject: |
It'll only be a problem when you go to remove the beam. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
GArBa Samba Member
Posted: Fri Nov 14, 2014 3:52 pm Post subject: |
that could be true, but why did they weld it there in the first place? If it was to add strength, I'd question the rest of their welding. If they simply were clueless on where to weld what... well that's not exactly confidence-inspiring. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Sat Nov 15, 2014 5:04 am Post subject: |
I think that the welder was following the previous "fix" job by the previous owner. As mentioned earlier there were a few welds that were not put there by the factory and from the looks of the previous pictures they were to the torsion tube. The welder told me that when the old plate was removed there was a lot of repair to do beneath it. To the tune of $2500.00CDN to be exact. These guys are a big operation that does work on mostly heavy machinery (transport trucks, bulldozers etc) so I really believe in their work. I just think that they thought that the plate was supposed to be welded to the tube. Thanks for your input, guys. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sat Nov 15, 2014 8:05 am Post subject: |
I can only imagine the grease fire that occurred with the welding of the beam.. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
