earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Oct 20, 2014 10:50 pm Post subject: Wheel adapters 4 lug to wide 5? |
OK
One of the last things I did on my last job running the waterjet machine was to make a set of wheel adapter to go from 4 lug to wide 5, I cut them out of 1/2" high grade aluminum, do you think this will stand up to some mild off road [no more then 1 foot of air] ...
I will use studs in the drums and rotors and large 1" hex lug nuts and studs in the adapter plate for the wheel. I know I can get rotors and drums in wide five but I cant afford them right now and I already have the adapters cut, I made 5, one will be a balance adapter.
Do you think they will be strong enough? Thanks for any help.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Brian Samba Moderator
Posted: Tue Oct 21, 2014 1:24 am Post subject: |
They look pretty sturdy. But I would put a seat in for the lugs, and some press in studs on the wide 5. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Oct 21, 2014 6:22 am Post subject: |
Brian wrote: |
They look pretty sturdy. But I would put a seat in for the lugs, and some press in studs on the wide 5. |
Yes...
jsturtlebuggy Samba Member
Posted: Tue Oct 21, 2014 1:15 pm Post subject: |
The Micro Stub setup used for racing uses a aluminum adapter like yours to go from the small 5 lug pattern to the wide 5.
One of the Class 5 Baja Bug I use to prep flipped over several times at about 80mph. When assessing the damage after, the micro stub hub had bent in the bearing area and the adapter was still straight and usable.
I think it will hold up well unless you are using an extreme off set wheel. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Tue Oct 21, 2014 7:59 pm Post subject: |
That thing looks beef. It should be fine. _________________ Member of the baja's that don't run club, for now!! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Mon Oct 27, 2014 3:03 am Post subject: |
Multi69s wrote: |
What grade of aluminum did you use? |
Multi69s
As far as I can remember its 6061 T6, I don't think we ever used any thing else in 1/2" plate. I cut them out over 2 years ago and my memory not as good as it used to be, I will look the rest of them over and see if there's any printing on one of them.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
HILLAHOLIC Samba Member
Joined: January 19, 2007 Posts: 110 Location: Elyria, Ohio
Posted: Mon Oct 27, 2014 9:32 pm Post subject: |
They'll be fine for extreme use. That's the same material I'm running on mine. It's been rolled hard 17 different times and they've held up.
[/youtube][/url] |
