Papas66 Samba Member
Posted: Thu Oct 09, 2014 7:49 pm Post subject: |
Pulled off calipers, time for new ones and brake hoses too.
Oh ya and the fuel pump is leaking........wonder how long this thing has been sitting.[/img] |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Thu Oct 09, 2014 10:14 pm Post subject: |
c21darrel wrote: |
Quote: |
Darn Darrel -- -- Water skiing???? |
Aint no snow in So Cal during the summer |
You could be one of those world travelers and flying to the southern extremes like some of my stupid friends -- -- I'm gonna have to hear the story behind this one -- better be good LOL _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
WooleyNelson Samba Member
Joined: July 13, 2012 Posts: 191 Location: Kokomo Indiana
Posted: Fri Oct 10, 2014 5:47 am Post subject: |
Yeah, I think any of us that are following this thread and Darrel's "Back in the Saddle" thread will be interested in "the Rest of the Story"! |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Fri Oct 10, 2014 9:27 am Post subject: |
Pulled off the pedal assembly to rebuild, finished rebuilding the fuel pump.
Ordered more parts from KGP&R _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
O2COOLED Samba Member
Posted: Fri Oct 10, 2014 5:05 pm Post subject: |
Finally found the time to finish installing the windlace and since I had to pull out the speaker panel, painted the front speaker grills dark chrome. Found the original bright chrome too blingy _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug |
Altema Samba Member
Joined: June 20, 2010 Posts: 2903 Location: Lower Michigan
Posted: Mon Oct 13, 2014 12:01 am Post subject: |
It got so cold here that I had to adjust the choke and idle volume screw to compensate for the temperatures being in the 30's (F). The choke was closing too far, but seems to open a bit too quickly. There's a two minute gap between where the choke is off and the engine is not quite ready for it. I was unable to find a shop that would weld the support tab onto my single QP muffler which had broken off, so I drilled and tapped it to install a bolt. I burned the glasspack out during the summer and the mellow tone is gone, but the quietpack sounds louder than it did before, and I don't think they have any internal insulation.
I also found out something weird: I have an electric fuel cutoff solenoid, and one day during the summer I was not comfortable with they way someone was watching the car, so I move the solenoid connection from the positive ignition coil terminal to the negative. I figured the car would stall out if they tried to steal it, and moving the connection to the wrong side would be less obvious than the terminal hanging loose. Then I forgot about it, and discovered I had been driving it that way for several months. Turns out the solenoid does not use that much power, and would open like a fuel injector each time the breaker points opened. I'm surprised it worked like that, but at least it made for a good durability test. However, it would also explain the funny points wear, lol. I have to say it runs better without the excess load on the points side of the circuit. |
67Cabrio Samba Member
Joined: March 30, 2014 Posts: 31 Location: Everett, Wa
Posted: Mon Oct 13, 2014 8:12 pm Post subject: |
Little new here, and a month new into the Ghia world (FINALLY!!). Today I installed a new oil pressure switch and cured the oil light problem. Kept fitting the cheap carpet I'm putting in for the time being, and pulled the rain tray for repairs. Still chasing electrical problems from past owners hacking however.
Much more has happened since taking ownership, but that's a longer story. Oh, and it's a '72 coupe! Not the lowlight like I wanted, but the price was right. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Tue Oct 14, 2014 5:48 pm Post subject: |
I'm almost run out of stuff to buy .... But yesterday I bought Hella E-Code H4 Headlights.
Today I bought a 1835 long block with a 110 cam. |
Posted: Wed Oct 22, 2014 7:03 am Post subject: |
Not today, but yesterday kept plugging away on the electrical problems. Found both brake switches bad, that was surprising. This weekend also picked up the rest of the pieces for a early front turn signal conversion, missing decklid scripts, and some other trim and rubber seals. Purchased a Type 4 case for the eventual turbo build for this car, yahoo! |
1966kghia Samba Member
Joined: October 20, 2014 Posts: 23 Location: Ontario, Canada
Posted: Wed Oct 22, 2014 12:24 pm Post subject: |
Registered the car in my name. Bought it Saturday, so it was due. Sorry, wish I had a better tale! |
waynethepain Samba Member
Joined: October 22, 2014 Posts: 5 Location: Argyle TX
Posted: Wed Oct 22, 2014 3:20 pm Post subject: 69 Ghia |
Today I put my 69 Ghia on a rotisserie. I mounted it to the engine supports and torsion bar mounts. It spins 360 and is a joy to work with.
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Sat Oct 25, 2014 6:56 pm Post subject: |
I tried to get the lug bolts loose so I could beat on the brake drums to try and free up the stuck emergency brake, no luck getting the bolts loose. |
RHough Samba Member
Posted: Mon Oct 27, 2014 6:12 pm Post subject: |
Drove 7 hours in crap weather to take my car to House of Ghia for a little resto over the winter. Got 27+mpg cruising 65-70 on the way down. |
Jeromerino Samba Member
Joined: February 28, 2013 Posts: 209 Location: Colorado
Posted: Tue Oct 28, 2014 1:45 pm Post subject: |
After another long Summer of my employer trying to suck the very life out of me, the time to go has arrived and crawling under the Ghia to give her a little love is in order. More money and fewer hours at work should help expedite things that have been pending for way too long already. First up is the rear brakes and those damn axle nuts are being stubborn as hell. Having an insufficient breaker bar is making matters worse than they should be, so I have word out to a few locals for a loaner and that shouldn't take very long. It's nice to get back at it. _________________ 1964 Karmann Ghia Coupe
1971 Beetle Sedan |
Altema Samba Member
Posted: Sat Nov 01, 2014 2:47 pm Post subject: |
RHough wrote: |
I hate driving mine in bad weather, and I only drove it once in the rain on purpose for a photo shoot. All the other times have been due to being surprised or trapped while already out. The irony is that the car drives so well in bad weather, and I'm warm and comfortable, but I hate knowing what the moisture does to old metal... |
rickpereira Samba Member
Joined: May 25, 2010 Posts: 330 Location: Sydney, AUstralia
Posted: Sat Nov 01, 2014 11:20 pm Post subject: |
wash claybar and wax..
Altema Samba Member
Posted: Sun Nov 02, 2014 3:36 pm Post subject: |
Jeromerino wrote: |
First up is the rear brakes and those damn axle nuts are being stubborn as hell. Having an insufficient breaker bar is making matters worse than they should be, so I have word out to a few locals for a loaner and that shouldn't take very long. It's nice to get back at it. |
Those axle nuts are always tough. I have 26 inch breaker bar and it was not enough. I want to a local shop and borrowed their big impact wrench, and it took 10 minutes of that, followed by the breaker bar.
You probably already know this, but for the right side of the car, set the brake, put the trans in first, and put a wheel chock behind the rear tire with the car on the ground. This way you can stand on the bar, as long as you have a really beefy bar. For the left side, put the chock in front of the tire.
Paul |
Altema Samba Member
Posted: Sun Nov 02, 2014 3:39 pm Post subject: |
Mmmm, yummy! The way the reflection is on that photo, it gives the illusion that the back bumper is Frenched.
crocteau Samba Member
Joined: March 31, 2005 Posts: 1203 Location: Philaburbia
Posted: Sun Nov 09, 2014 10:20 am Post subject: shine on! |
With the Marine Corps' birthday coming up, I declared today to be Mothers (metal polish) day here. All the bare metal parts are getting the full treatment, including the you know what. The shine on these intakes alone should add at least 5 HP to my Ghia LOL
[/i] |
Posted: Mon Nov 10, 2014 2:08 pm Post subject: Finished painting car today |
Painted, now I take soon time off. I wore out my shoulder out with sanding and painting this weekend.
