kdd702 Samba Member
Joined: October 29, 2014 Posts: 11 Location: United States
Posted: Wed Oct 29, 2014 9:31 pm Post subject: Alternator/Regulator problem (12v) |
I recently acquired a VW bug and fixed a few things and bought some parts. I picked up a new generator, polarized it and it puts out the right amount of volts. I also got a new regulator for it, however when I hook the positive lead to the generator it kills the voltage that the generator was putting out.
Any help? |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Thu Oct 30, 2014 2:50 am Post subject: |
The title says Alternator/regulator but you say you have a generator. Just to be clear, the generators are the same diameter along their length. Alternators are fatter at the pulley end than the fan end.
You don't say exactly how you polarised it either, so...
If it is a generator, follow this procedure and it will help you diagnose the cause of the problem.
www.vw-resource.com/generator.html
If you do in fact have an alternator, these NEVER need polarising - they use different metals to generators and so they don't hold a residual magnetic field to get the alternator started. Instead they use the small current through the dash Alt bulb to excite the Alt into action. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Thu Oct 30, 2014 5:54 am Post subject: Re: Alternator/Regulator problem (12v) |
kdd702 wrote: |
I recently acquired a VW bug and fixed a few things and bought some parts. I picked up a new generator, polarized it and it puts out the right amount of volts. |
Could you maybe provide more details?
List the parts you replaced or don't bother mentioning them at all.
Why did you buy a new generator? What was wrong with the old one?
How many volts does the new generator output? 12.0v? 12.6v? 13.8v? 14.5v?
Was this at idle or with the rpms higher?
What was the static voltage at the battery when you did this?
kdd702 wrote: |
I also got a new regulator for it, however when I hook the positive lead to the generator it kills the voltage that the generator was putting out. |
Why did you need both a new generator and VR?
Does the positive terminal on the generator have a designator stamped next to it? Is it D+? Is it DF?
If you have a generator, you realize the battery does not connect directly to the generator? The B+ cable from the battery connects to the B+ terminal of the VR. The heavy gauge red wire from the VR D+ terminal is what connects to the D+ stud on the generator. _________________ AshMan40
