cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2400 Location: Gladstone, Ore
Posted: Thu Oct 30, 2014 5:39 pm Post subject: Brake lights quit |
Noticed it today, last checked about 2 weeks ago.
Didn't check bulbs because all 3 are out, have an LED strip as the third light.
Fuse is good, fan on same fuse works, horn on same wire bundle works.
Guessing been running on one working brake light switch for some time, now the other has quit. Unknown vintage or manufacture of said switches.
Question: Should have power to black wire to switches with key on, correct?
Secondly, is the fact my dimmer switch quit also somehow related?
72 super, fairly unhacked wiring, not original pristine but I know what goes where.
Thanks _________________ 1972 1302
HPMX 40's & 019 |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Thu Oct 30, 2014 7:50 pm Post subject: |
I believe black is power in to switch, red/black is power out to the lights when the brakes are engaged. This might help:
http://www.speedyjim.net/schem/3brake.gif
edit: mine work with key on but I'm not sure it's "correct" _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Thu Oct 30, 2014 9:55 pm Post subject: |
ROCKOROD71 wrote: |
edit: mine work with key on but I'm not sure it's "correct" |
The key has to be in "run" position for the brake lights on these, at least to 1971 (my newest). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
CB_Strange Samba Member
Joined: December 17, 2012 Posts: 48 Location: Springfield, MO
Posted: Fri Oct 31, 2014 8:25 am Post subject: |
Cusser wrote: |
The key has to be in "run" position for the brake lights on these, at least to 1971 (my newest). |
Same with my '72. _________________ --------------------------
1972 Super Beetle
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Tue Nov 04, 2014 8:24 am Post subject: |
I have had brake light switches go bad many times either electrics or leaks. Now I use the switch for a ground now to ground a relay, the relay carries the load to the lights, have not had one burn out in years. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Posted: Tue Nov 04, 2014 8:29 am Post subject: |
Greezy Joe wrote: |
I have had brake light switches go bad many times either electrics or leaks. Now I use the switch for a ground now to ground a relay, the relay carries the load to the lights, have not had one burn out in years. |
Adding a relay is the best thing you can do.
Those little switches have to handle a load of 55 Watts.
adding a relay, takes that load off of them. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
