mark tucker Samba Member
Posted: Tue Oct 28, 2014 8:48 am Post subject: |
I dont realy fully grove my mains, I do a partial grove leave about1/2" un groved like the calies bearings I used to get for v8 stuff.I dont have bearing issues.over bearing issues...... possiably |
AlteWagen Troll
Posted: Tue Oct 28, 2014 11:24 am Post subject: |
some pics to make it easier
On the left is a KS bearing for use on a non cross drilled crank. The bearing on the right is for use on a cross drilled crank.
Here is a late VW of Mexico cast crank with cross drill oiling (any 1600 forged German crank is the same)
69mm 1500 and many aftermarket stroker cranks are not cross drilled requiring the use of the KS bearing to allow full 360* oil to the rods. Below is a 82mm Scat crank that is not cross drilled but has the journal modification to allow full oiling while using a non cross drilled type bearing.
_________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Tue Oct 28, 2014 2:27 pm Post subject: |
Yes, the center bearings can be grooved on a lathe. A fixture must be made to hold both halfs at once. It's not that difficult to do by hand with a Dremmel tool. I tape off both sides of the bearing to protect it and it gives a straight edge to go by. As I said before, I make the groove about .030" wide and as deep. _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
85burb Samba Member
Joined: February 26, 2014 Posts: 220 Location: Lindale Tx
Posted: Tue Oct 28, 2014 5:02 pm Post subject: |
I went and looked at his bearing today. He did groove it but I don't think it was wide enough. And was not centered well. He does have a lathe and he is pretty smart so I am betting he can groove them better some how. He tore a core motor down when I was there that he is gonna build for his next race motor. So we will get to try again. _________________ 1964 beetle
1974 standard beetle |
Posted: Wed Oct 29, 2014 8:35 am Post subject: |
Would it help or harm to make another hole through the bearing at the midway point? _________________ 1958 Karmann Ghia owner |
85burb Samba Member
Posted: Wed Oct 29, 2014 9:50 am Post subject: |
Northof49 wrote: |
Would it help or harm to make another hole through the bearing at the midway point? |
I was wondering that today. I came across a picture of a 944 main bearing and it has slots that go threw the bearing all the way around. _________________ 1964 beetle
AlteWagen Troll
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Wed Oct 29, 2014 9:12 pm Post subject: |
here's another way center main is drilled. |
drumbum68 Samba Member
Posted: Thu Oct 30, 2014 11:26 am Post subject: |
It's all Bergy and stuff. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Oct 30, 2014 1:15 pm Post subject: Re: Cb crank oiling question |
85burb wrote: |
I thought I read someware on here that the oiling holes in the cb crank require oil system mods. My friend has just spun a rod bearing in his circle track motor and compleatly distroyed the hole motor. I am pretty sure it's a 82 stroke with the really nice cb rods. He has built vw motor and vw and ford race motor for ever. This is his second motor to fail like this this year. It was turning 7-7500 rpm when the rod let loose. The motor only had 3-4 races on it and the oil filter has been cut open after every race. No metal was ever found. I would think the rods would hold up to 7500 rpm. Any ideas? |
I've recently used two "out-of-the-box" CB cranks (78.4 mm & 84 mm) WITHOUT any modifications to the crank or bearings. Both used CB H-beam rods.
I prefer the steel-backed bearings with outer groove and the two inner scoops (360 groove not needed).
This is in my street-strip Beetle with over 300 races (1/4-mile) on each crank plus 23,000 street miles. Same standard main bearings for both cranks and no rod bearing issues (two sets used when switching from VW size to Buick for the 84 crank).
I have the rev limiter set anywhere from 7500-7900 rpm. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Thu Oct 30, 2014 3:54 pm Post subject: |
Neil68.. do you use 26mm. Or 30mm. Oil pump? And what weight oil? |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu Oct 30, 2014 5:47 pm Post subject: |
I refrained from....... refraining because it wasn't part of the question...........BUT.
The FIRST question to ask is what was the rod bearing clearance??
Second what oil and lets see the air filter.
Then we talk about bearing grooves |
85burb Samba Member
Posted: Fri Oct 31, 2014 4:22 am Post subject: |
I am not sure about the rod bearing clearance. But he turns them so they are all strait up and makes sure they fall at a good speed and all the same. The oil is 15-40 for sure. He has a holley 500 two barrel carb and uses a big round tall air filter that has a outer wrap on it. I think he has a 30mm pump in it. Non full flowed. He is very against full flow cases and of all things duel carbs. _________________ 1964 beetle
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Fri Oct 31, 2014 5:49 am Post subject: |
85burb wrote: |
I am not sure about the rod bearing clearance. But he turns them so they are all strait up and makes sure they fall at a good speed and all the same. The oil is 15-40 for sure. He has a holley 500 two barrel carb and uses a big round tall air filter that has a outer wrap on it. I think he has a 30mm pump in it. Non full flowed. He is very against full flow cases and of all things duel carbs. |
That's not gonna cut it , fall at the same speed ?/ he needs to know what clearance ??? _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608
Posted: Fri Oct 31, 2014 10:20 am Post subject: |
agnist full flow??? just smile and sell him some more parts and a box of chockalattee candies. stupid is as stupid does. ( not including spellen teacher test's) |
modok Samba Member
Posted: Fri Oct 31, 2014 4:24 pm Post subject: |
Ok then it's pretty clear cut. the 15-40 oil is OK choice, but Failed because you can't use thick oil with tight bearings.
Have the crank ground for .0025-.003 bearing clearance and try again.
I am sure the main and cam bearings are ruined too from not having an oil filter. |
Posted: Fri Oct 31, 2014 4:53 pm Post subject: |
modok wrote: |
As a rule you should have 1 thousandth for every 1 inch of journal and if your revving the shit out of it for long periods then modok is right on .. I like the .0025 _________________ " Hot vw feature , may 2014 issue "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
modok Samba Member
Posted: Fri Oct 31, 2014 4:59 pm Post subject: |
you betcha!
And also consider oil flow and flex. There is a lot of flex in the crankshaft, so not a good idea to have your rods significantly tighter than the mains. If the rods are trying to keep the crank straight it will certainly result in more friction and heat!! |
Posted: Fri Oct 31, 2014 5:01 pm Post subject: |
and skeered of dulling crabs......he's lost without hope of finding him self.those are the kinda guys I refer to toyota for a car.sorry but I call it as I see it. some have it some dont,some think they do and those who do just smile and nod thier head.kinda like cant teach old dogs new tricks but they sure do buy a lot of defective parts to eat up. |
