Blackoutt Samba Member
Joined: March 03, 2012 Posts: 240 Location: Waterford, MI
Posted: Fri Oct 10, 2014 10:57 pm Post subject: ecotec throttle cable |
Hey guys just curious what you have used or ideas on what you'd recommend to run for throttle cable. I've seen a few decent ideas, just looking for a little input from some of you.
Thanks |
Sandbar Norm Samba Member
Joined: August 02, 2008 Posts: 115 Location: A Sandbar in Fl.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Oct 11, 2014 6:18 am Post subject: |
Try local hardware store.... I found a local store that had small diameter stainless steel cable by the foot....
shephard_scott Samba Member
Joined: April 25, 2011 Posts: 82 Location: Flint, Michigan
Posted: Sat Oct 11, 2014 9:21 am Post subject: |
I used the stock cavalier throttle cable and made a bracket off of the trans to hold the end. The throttle cable I already had on the buggy before the engine swap is a 1/4 in brake line with a bugpack braided cable running through it. I connected them together at the bracket with cable clamps. Haven't had any issues with it just make sure you have a throttle stop so you are not putting too much pressure on it.
turboghia Samba Member
Joined: February 15, 2004 Posts: 210 Location: Long Beach, Ca.
Posted: Sun Oct 12, 2014 8:44 am Post subject: |
I used these guys. These guys make an awesome cable. I measured the length i needed and they had it ready in just a few days. The quality is great and it is smooth as butter, no drag whatsoever.
http://www.controlcables.com/
Steve |
Posted: Fri Oct 31, 2014 11:50 am Post subject: |
Ok guys I went with a morse cable, but I'm looking for ideas how some of you did the motor end hookup. Already have the pedal setup figured out with a quick connect. |
