MalibuLX3 Samba Member
Joined: October 02, 2005 Posts: 821 Location: Rochester, MI
Posted: Thu Oct 30, 2014 7:04 pm Post subject: How to tell if a transmission is usable with no motor? |
Hey guys,
I have a friend that just picked up a buggy without a motor, and he is wondering about the condition of the transmission.
We know that the transmission was previously fine, and the engine was not pulled because of a faulty transmission, but just a wore out motor that never made it back in the buggy. However, the buggy has sat, basically unmoved and without a motor for probably 10 years until he got it now.
Currently, the transmission does not turn very easily with a pair of vise grips on the input shaft. The transmission also does not shift into 3rd or 4th gear. Maybe it will turn better when he gets something besides a pair of vice grips on it, but we're not sure if this is normal or not.
Any ideas on evaluating the condition of this transmission is greatly appreciated! _________________ 1978 Westfalia |
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Fri Oct 31, 2014 6:42 am Post subject: |
IRS or swing axle? An IRS without axles and tires hooked up should shift and turn by hand as normal. At least that has been my experience. Sometimes the shifter gets a little stiff though. Might have to use visegrips to get it loose again. _________________ Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja |
winchin73blazinbaja Samba Member
Posted: Fri Oct 31, 2014 6:48 am Post subject: |
it would not hurt to change fluid in their either. that may help free it up 10 years of sitting can do some funky stuff. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Fri Oct 31, 2014 2:20 pm Post subject: |
Thanks for the info guys, I"ll pass this along and I'm sure it will be helpful! If anyone has any addition information, please let me know and I'll pass that along as well.
Thanks! _________________ 1978 Westfalia |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Sun Nov 02, 2014 8:07 pm Post subject: |
Unfortunately, there is no way to test a transmission out of a car to see if it is "GOOD". You can have worn out syncros rings, operating sleeves, or bad bearings, and the transmission can still be shifted, and everything turns smoothly. It is not until you put a load (drive) with the transmission, that many of the gremlins will rear their ugly heads. That's when it will pop out of gear, the R&P howls, or you can not shift it at all.
ALL transmissions that I can not drive are considered parts transmissions and I will only pay what is considered a core price. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
