gladi8r Samba Member
Joined: November 10, 2014 Posts: 14 Location: Fullerton, CA
Posted: Tue Nov 11, 2014 9:28 am Post subject: Diesel Issues |
Hey everyone, I'm a newby from socal, just picked up a Vanagon (84) with an unfinished 1.9 AAZ conversion. I was told the motor was fine and low miles out of a Passat (96) and I did something pretty absent minded (stupid) that may be causing my problem. I was having trouble getting fuel up from the tank so I hooked up a gravity feed tank that I had rigged previously. Anyway, the stupid part is that I hooked it straight into the injection pump, not thinking about the fuel filter. For a second it seemed like it was going to run good (not sure) but basically it will only idle and won't take more fuel without dying. I ran it a bit and then obviously realized the filter was not hooked up. I tried to run it a bit after hooking up the filter and put a good jolt of cetane booster hoping it would straighten out. The problem persists though a plan to run it more and hope it dislodges something in the pump or some miracle happens. I know nothing about diagnosing this type of problem or tuning these motors so I'm pretty stuck. Anyone have any ideas or somewhere I can turn to try to work through this? It's pretty frustrating because I had a great time building an exhaust, intake and some other stuff and I thought I was going to be on the road. Any and all help appreciated. Steve in Fullerton. |
