Original vw muffler modified "abarth style"
Frederik
Frederik is offline
PostPosted: Thu Oct 23, 2014 11:42 am    Post subject: Original vw muffler modified "abarth style" Reply with quote
My original vw muffler finally fell apart this spring so I desided to give it a "abarth look-a-like" overhaul. The idea is to have a 4 tip muffler with the vw original "equal lenght" guts.
On my stock 36hp engine.
bdub475
bdub475 is offline
PostPosted: Thu Oct 23, 2014 3:18 pm    Post subject: Reply with quote
How does it sound? I have been considering doing the same thing to a 40hp muffler.
henry roberts
henry roberts is offline
PostPosted: Thu Oct 23, 2014 5:09 pm    Post subject: Reply with quote
awesome! Cool sounds good.
damn I love seeing old beetles being driven on dirt roads.
54ovsemi
54ovsemi is offline
PostPosted: Fri Oct 24, 2014 1:45 pm    Post subject: Reply with quote
Sounds great! Did you use Stainless tubing for tips? Cool videos too Cool
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
Frederik
Frederik is offline
PostPosted: Sat Oct 25, 2014 4:12 am    Post subject: Reply with quote
It's 35mm O.D./ 32mm I.D raw stainless tubes I polished up. One Idea was to simply use them in stock outlets on a NOS original vw 36hp exhaust I have as "cleaned out" pipes.
Jacks
Jacks is offline
PostPosted: Sat Oct 25, 2014 7:24 pm    Post subject: Reply with quote
Well, that turned real quite nice. I have to admit that I had doubts when I saw the first mock up. Really, very nice job! Cool
Jack Staggs
Actual name
mark tucker
mark tucker is offline
PostPosted: Tue Oct 28, 2014 8:56 am    Post subject: Reply with quote
I would use a new muffler,cut it open and rework it then add the abarf tips
mark tucker
PostPosted: Tue Oct 28, 2014 8:58 am    Post subject: Reply with quote
I would use a new muffler,cut it open and rework it then add the abarf tips. or build a new muffler with 4~5" stainless tubing and make it so it works like a 4 into 2 into 1 out 4
snowbug
snowbug is offline
PostPosted: Sat Nov 01, 2014 7:55 am    Post subject: ABARK Reply with quote
here is my 4 tip home made A-bark muffler.
bdub475
bdub475 is offline
PostPosted: Sat Nov 01, 2014 11:44 pm    Post subject: Reply with quote
Very nice car snowbug. I couldn't hear the exhaust at all on your drive, all i could hear was wind the the camera mic.
snowbug
snowbug is offline
PostPosted: Sun Nov 02, 2014 9:58 am    Post subject: Reply with quote
It is quite loud inside the car. Has a very low sound. I used a NOS round bus muffler and 4 taper tips to make the fake Abark.
Stocknazi
Stocknazi is offline
PostPosted: Tue Nov 18, 2014 2:45 pm    Post subject: Re: Original vw muffler modified "abarth style" Reply with quote
Sounds great.
Why is the popping sound when you let off the gas? Too little backpressure or is that common with 4 tips?
If you did not add the wadding to the ends of the muffler how do you think it would affect the sound?
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
Stocknazi
PostPosted: Thu Dec 11, 2014 7:08 am    Post subject: Reply with quote
Is the popping sound when shifting b/c there is too little backpressure.
I have a round muffler that needs some repair and was wanting to make a Arbarth 4-tip copy as well.
Sounds great, but the popping sound when shifting would be nice to eliminate.
Any ideas?
WANTED:
Thomas Jefferson
