theDrew Samba Member
Posted: Thu Nov 13, 2014 9:29 am Post subject: |
forget what I said, its back again. damnit all.
how bad is it on the engine? I'm still trying to use it during all this "testing" _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Fred Winterburn Samba Member
Joined: April 17, 2013 Posts: 423 Location: Ripley Ontario Canada
Posted: Thu Nov 13, 2014 4:18 pm Post subject: |
theDrew wrote: |
how bad is it on the engine? I'm still trying to use it during all this "testing" |
While on the starter, two potential problems arise. I do not know if the Black Box is susceptable, but many electronic devices can be. The obvious problem is one of low battery voltage as the heavy current draw of the starter drags the voltage down. This can be an issue with some electronics that aren't tolerant of low battery voltage. The other issue with some starter motors is one of voltage spikes. Many starters will generate high voltage spikes that can also affect some electronic devices. I do not know if the Black Box is susceptable to voltage spikes or low battery voltage (or both). The question needs to be asked as these are possible reasons for your timing difficulties while on starter. Good luck with it, Fred |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Thu Nov 13, 2014 5:29 pm Post subject: |
Porsche60 wrote: |
#2 Sometimes the timing jumps to 70 degrees.
Weak battery or noise? Undiscoverd.
It must not happen because it may heavily damage the engine.
I don't think I have this issue, I don't think it would be a software bug. Could it physically be related to distributor, like an issue with it "unlocking" sometimes?
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Porsche60 Samba Member
Joined: December 27, 2007 Posts: 210 Location: Far East
Posted: Fri Nov 14, 2014 9:24 pm Post subject: |
stan_tichomirov wrote: |
Porsche60 wrote: |
Stan |
I haven't checked this issue. j-dub mentioned it.
I don't think it is unlocking.
If the distributor once unlocked, it would never locked again.
70 degrees is where the distributor point set at.
It would be a problem of software or hardware inside the black box.
Or maybe noises and low voltage would mess it up. |
Posted: Tue Nov 18, 2014 7:03 pm Post subject: |
I'm sorry to cut in line of the cranking issue but
I should add another Pro of the Black Box (or any programmable ignition with MAP sensor)
I've already mentioned about it in an older post.
This description is based on N/A engines.
The pro
You have two cars, one has SVDA and another has the black box.
If you go higher altitude while timing properly set at sea level,
SVDA's timing would be retarded compared to the black box.
It means less performance and less fuel efficient with SVDA.
The black box advances ideally at any altitude.
Why?
Ignition timing should be advanced or retarded depending on the manifold pressure,
because the manifold pressure is directly related to burning speed of fuel mixture and the chance of knock.
The manifold pressure almost equals to the atmospheric at WOT.
When the atmospheric changes, the manifold pressure also changes.
The WOT manifold pressure at a hill top would be lower than sea level (100 kPa), let's say 90 kPa for example.
So the timing should be advanced a few degrees more than at sea level.
The black box uses MAP (Manifold ABSOLUTE Pressure) sensor
so that can compensate timing ideally, whatever the atmospheric pressure is.
On the other hand, SVDA's vacuum unit can't sense any absolute pressure.
It just compares the manifold pressure to the atmospheric.
And it advances timing if the manifold pressure is lower than the atmospheric.
The vacuum unit won't advance at WOT whatever the manifold pressure is.
Note
In reverse, higher to lower altitude could be a problem for the Black Box as well as SVDAs.
If you live in high altitude and tune your black box only in your town,
you will never see higher MAP than the atmospheric, let's say 90 kPa.
So you may not set the maximum MAP on the timing table up to 100 kPa.
Then, if you go down to the beach, your timing might be too advanced near WOT.
It is important to set timing up to 100 kPa if you go sea level.
Then, virtually you will never need to adjust timing at any altitude. |
GTV Samba Member
Posted: Tue Nov 18, 2014 7:44 pm Post subject: |
I gotta say, the CB Black Box really looks like the bees knees. But as long as this kickback issue remains a problem, it will keep me from buying one. I hope CB gets it sorted out. _________________ EMPI Power Rules! |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed Nov 19, 2014 12:09 pm Post subject: |
Porsche60,
That is all quite true. The issue is if you have a block in your map programmed for extra advance at a lean cruise at zero elevation, when you go up in altitude (down in pressure) you will be operating in this highly advanced portion of the map when under heavier load.
That is where a second map sensor, a barometric sensor, comes in handy. My ECU has two map sensors, one for the engine and one that measure real time barometric pressure. It has supplemental maps that must be programmed to offset both the fuel and ignition timing wrt barometric pressure.
Most bare bones ECUs with a single pressure sensor only measure barometric pressure at key on and it is static until power cycling. |
Posted: Fri Nov 21, 2014 9:23 am Post subject: |
BTW, this is my current timing map.
It's not much changed from the map posted in page 3, in high RPM and high MAP area.
Mainly, I changed idle, cranking, low RPM driving, and decel.
I can't improve more from this point without dyno. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Fri Nov 21, 2014 7:41 pm Post subject: |
For the sake of discussion here is my latest map, wanted to add more timing in the cruise section.
_________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
EVfun Samba Member
Posted: Sat Nov 22, 2014 11:53 pm Post subject: |
Has anyone running this without a carb system that doesn't have a choke tried to set the idle timing so it has a minimum advance at around 1000 rpm (at higher vacuum levels seen with the throttle released) and advances as the idle speed declines? Advancing the timing has the habit of increasing the engine rpm. My thought is that by advancing the timing as the idle speed went from 1000 rpm down to 500 rpm it should help keep the engine running after a cold start. _________________
Wildthings wrote: |
Posted: Sun Nov 23, 2014 7:52 am Post subject: |
EVfun wrote: |
Has anyone running this without a carb system that doesn't have a choke tried to set the idle timing so it has a minimum advance at around 1000 rpm (at higher vacuum levels seen with the throttle released) and advances as the idle speed declines? Advancing the timing has the habit of increasing the engine rpm. My thought is that by advancing the timing as the idle speed went from 1000 rpm down to 500 rpm it should help keep the engine running after a cold start. |
I think ignition timing won't help cold idle.
Difficulty of cold idle is caused by fuel system.
While the engine is cold, the manifold is lacking heat to vaporize the fuel.
If the fuel doesn't vaporize, it can't flow and reach to intake ports.
The engine will stall.
Choke helps this problem.
But you can't help this with ignition timing. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Nov 23, 2014 9:11 am Post subject: |
Porsche60 wrote: |
EVfun wrote: |
So.......why does Megasquirt have cold idle advance????? _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Nov 23, 2014 10:12 am Post subject: |
Even on vacuum advance carbs, you will notice when the choke is on, it holds the throttle plate open so as to expose he vacuum port, among other things. |
j-dub Samba Member
Posted: Sun Nov 23, 2014 11:19 am Post subject: |
On my engine i was playing with the idle timing based on RPM. For example my target idle RPM is 850:
750 RPM 15 deg
850 RPM 12 deg
950 RPM 8 deg
You can adjust your numbers accordingly but the idea was when it was cold and idling lower the extra RPM would keep it from idling slow. I was pretty effective, however I abandoned it during starter kickback troubleshooting. _________________ 1957 Oval rag
mark tucker Samba Member
Posted: Sun Nov 23, 2014 11:26 am Post subject: |
so... your pulling timing out at low rpm as the rpm increases???Ilike low timing at spinning then add when it fires off& comes up to idle at about 13 degrees idle speed,no kick back smooth idle,but I dont have one of these fancy boxes. not sure I could keep all my hair with all those numbers on that chart.I only have 8 fingers. |
j-dub Samba Member
Posted: Sun Nov 23, 2014 4:48 pm Post subject: |
Yep, the idea is completely optional but is fun to set up.
You set your cranking timing to what ever you need, 8 degrees or so. Once it fires off the RPMs increase to the next timing bin. This second bin would add timing to keep the idle speed up when it is cold. The target idle speed would be the third bin and would be whatever you engine likes and the fourth bin bin up would be to control hot idle and would have lower timing, however I have never found it necessary.
As soon as you hit the throttle it would be on the next bin, out of the idle range, so this dip in timing would not be noticed.
Hope that makes sense. _________________ 1957 Oval rag
Posted: Mon Nov 24, 2014 6:12 am Post subject: |
what number is advanced?
I run 14 degrees idle and it is advanced than stock 7.5.
But it doesn't help cold idle.
My carb is single and fuel evaporation is the problem.
For the Megasquirt, I think it advances timing along with enrichening AFR while cold.
Plus, fuel injections don't have evaporation problems.
It's different story.
Black box has no temp input so you can't change timing depending on temp.
I don't find significant RPM or MAP difference between temps.
If you set idle for cold temp, it's not good after warm up.
The stock carb and distribtor setup has similar idea that works together with choke.
It's done by ported vacuum.
Stock choke opens the throttle plate a little, which increases RPM and enables the ported vacuum.
At this time, vacuum advances timing +10-12 degrees.
Once the engine is warmed up, throttle plate closes and ported vacuum is closed.
Zero vacuum advance and back to 7.5 degrees.
I emulate that, of course with choke system.
Choke is the only temp sensor on my engine. |
Posted: Mon Nov 24, 2014 7:18 am Post subject: |
EVfun wrote: |
I reread the post and I remembered that I tried it once.
But yeah, then another problem happened and quit playing with idle.
Again, it helps only a little.
I have stock auto choke system but no preheat hose to the carb.
It stalls after choke warmed up and manifold is still cold.
Ignition timing won't help this problem much. |
kikkegek Samba Member
Joined: September 27, 2014 Posts: 23 Location: Netherlands
Posted: Fri Dec 26, 2014 7:01 am Post subject: |
I am experiencing some strange stuff I wanna share with you guys.
I have a Autogauge vacuum gauge in my dashboard and it read different values as the BB.
this one:
BB Gauge
-2,2 VAC 0 inch
-12,2 VAC 15 inch
-9 VAC 12 inch
-15 VAC 18 inch
-17 VAC 22 inch
I have asked Mark from CBP about it and the manufacturer of the MAP sensor says that it is wel within the range of accuracy of the 5 BAR MAP sensor.
I was wondering if any of you guys have compared these values?
another thing is I found a bug in the timing table. During WOT runs the timing would jump from the right of the table to the left of the table, causing hesitation during acceleration. this was because the reading would go off the chart and therefor jump to the other side. it is solved by making sure you choose bounderies you will not reach during operation. I found out together with Mark, maybe there is a update by now that fixed it?
my last problem I am having is rough idle and hesitation during take off when the engine is warm. Iĺl start loosing connection to the black box and idle quality will become pretty bad. when I take of the first few feet are rough, then it smoothens out and runs fine....I have absolutely no clue what maybe causing it.
Do you guys have any tips?
What are you guys using for signal input for the Black Box? |
Posted: Fri Dec 26, 2014 7:16 am Post subject: |
kikkegek wrote: |
this one:
BB Gauge
-2,2 VAC 0 inch
-12,2 VAC 15 inch
-9 VAC 12 inch
-15 VAC 18 inch
-17 VAC 22 inch
That issue was discussed here before.
My black box reads 90-91kpa at sea level (101kpa).
Plus, the vacuum gauge might be inaccurate also.
Unless you replace your black box to new one, it would be ok.
Well, I wanna replace mine with more accurate one.
I didn't know about the jump from right to left.
Good info!
For the rough idle and losing connection,
it might be too much resistance or too low voltage between the coil and the plugs.
I'm not sure though.
What coil, distributor, ignition wire and plug gap do you have? |
