HIROLER Samba Member
Posted: Wed Nov 19, 2014 10:49 am Post subject: 1960 Lowered two clicks tire rub!!! |
I just lowered my 60 and noticed that my tire tires are rubbing the rear body mount. I have lowered my other bugs two clicks and never had this trouble before. ADVICE? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Nov 19, 2014 10:57 am Post subject: |
Raise it back up a "click"
2 inner? 2 outer? combo of inner and outer?
Lots of "clicks" round here..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Wed Nov 19, 2014 12:15 pm Post subject: |
Two outer clicks |
Posted: Wed Nov 19, 2014 12:24 pm Post subject: |
HIROLER wrote: |
Two outer clicks |
Well there ya go..
Each outside splines give approx 8 degrees of change.. you went 2 so thats approx 16 degrees.. equates to little over 2 inches.
Its going slam the ass end
Depending on tire and wheel configurations it very well could rub..
PLUS... if the torsion bars are a little fatigued.. 2 clicks can actually drop it more than expected..
What wheels?.. what size tires?.. Both sides?
Posted: Wed Nov 19, 2014 5:26 pm Post subject: |
Stock 15"wheels with 165 tires. Yes it's rubbing on both sides. I just narrowed the beam with adjusters and 2 1/2 drop spindles. So the back needs to be low, but two clicks just rubs. |
Posted: Wed Nov 19, 2014 6:38 pm Post subject: |
Hmmmm sounds like weak torsions.. You may have to make adjustments with inner and outer splines to get it where ya want it.
Search torsion spline chart.
Posted: Thu Nov 20, 2014 9:04 am Post subject: |
Thanks |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Nov 20, 2014 2:47 pm Post subject: |
Tires rubbing may end up being the least of your troubles.
But have you considered wheel spacers to get the tires off the body mounts?
Or maybe just grind the body mounts away. There are plenty of other bolts holding the body on. _________________ Mother Nature is a Mean Evil Bitch! |
R33ce97 Samba Member
Joined: October 23, 2013 Posts: 275 Location: North Georgia
Posted: Thu Nov 20, 2014 4:35 pm Post subject: |
My '66 is lowered two clicks. stock spring plates ride on the metal stop and my tires don't rub. cant remember what size they are. I need to get drop plates though. _________________ If you don't know what you're doing, it's best to do it quickly.
'73 super- sold
'66 beetle
'65 sunroof bug
'71 f-100, 302 |
Posted: Fri Nov 21, 2014 7:36 am Post subject: |
R33ce97 wrote: |
My '66 is lowered two clicks. stock spring plates ride on the metal stop and my tires don't rub. cant remember what size they are. I need to get drop plates though. |
That must be a really nice ride if the spring plates are sitting on the stops. _________________ Mother Nature is a Mean Evil Bitch! |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Fri Nov 21, 2014 9:00 am Post subject: |
What do drop plates do? Do they lower the back if you do not change the "clicks". I do not like the "Broke" look (Rear Tires canted in) but do like lower. Would drop plates help? _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Posted: Fri Nov 21, 2014 9:07 am Post subject: |
tb03830 wrote: |
What do drop plates do? Do they lower the back if you do not change the "clicks". I do not like the "Broke" look (Rear Tires canted in) but do like lower. Would drop plates help? |
There are fixed drop and adjustable drop spring plates.
Both are usually installed at stock spring plate angles.
Fixed result in a given amount of drop built into the plate, while adjustable allow adjustment.
Either will drop the rear, obviously adjustable allows fine tuning.
Both yeild a saggy bottom look on a swing axle....
Posted: Fri Nov 21, 2014 9:10 am Post subject: |
VOLKSWAGNUT wrote: |
Saggy bottom? Don't know that term.
Thank for the info on the types that helps. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Fri Nov 21, 2014 9:11 am Post subject: |
tb03830 wrote: |
You still get the same change in camber (broke look) with drop plates. Drop plates have elongated toe adjustment slots so that you can run proper toe while lowered. They are also designed so that they don't interfere with the travel limits at the torsion bar housing ends.
Also, if you do to the work of installing a drop plate, you have removed the old torsion plates and therefor still have to set them up for the desired amount of drop.
The big advantage I can see would be to be able to run the correct amount of toe, as you quickly run out of adjustment with the stock torsion plates and end up running excessive toe in. _________________ 1958 Karmann Ghia owner |
Posted: Fri Nov 21, 2014 9:28 am Post subject: |
tb03830 wrote: |
Merely a saggy bottom reference.. not hating on anyone..Its just not my thing..
Once you lower the rear swing axle past level axle... its sags towards severly negative camber... (and positive damage)
If you want to lower the rear slightly... the torsions can be adjusted with a series of inner and outer splines to just about any height.
Its cheaper that way..
Adjustable plates are for those who really like to fine tune the height and have money to waist (over time)..
This is the style I refer to as.... the saggy bottom bugs...
Posted: Fri Nov 21, 2014 9:30 am Post subject: |
Ok, Thanks, That is what I was calling the "Broke Look". Not my thing either. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Fri Nov 21, 2014 9:38 am Post subject: |
tb03830 wrote: |
Ok, Thanks, That is what I was calling the "Broke Look". Not my thing either. |
Broke look or saggy bottom.. both look real cool when its on the side of the road with burnt out fulcrum plates or drum splines..
Goes from your "Broke Look" .. to broken
Fine for show ...I guess.... but sucks for go..
This style didnt really start showing up until all the ricer boys and girls started dumping theirs way down in the dirt... so some followed suit...
Same can be noted with the tricycle look front beam...
Narrow a beam to fit wheels under a fender..... .but so far under to loose sight of them... I dont get..
To each their own.. not my circus..not my monkeys..
I lower all my vehicles.. Just know when to say when..
Posted: Fri Nov 21, 2014 1:29 pm Post subject: |
The main two things that drop plates do for you is to give you the toe adjustment already mentioned. But they also allow you to get your spring plates off the stop and have a little suspension travel.
The only way to get rid of the broke look on a low swing axle car is to do a transmission raise and get the axles back to being level. Thats big modifications. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Nov 21, 2014 1:40 pm Post subject: |
drscope wrote: |
The only way to get rid of the broke look on a low swing axle car is to do a transmission raise and get the axles back to being level. Thats big modifications. |
Or a CV joint (IRS) swap...
EVfun Samba Member
Posted: Fri Nov 21, 2014 4:33 pm Post subject: |
How do the axle bearings survive with that much negative camber? _________________
Wildthings wrote: |
