What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 376, 377, 378 ... 628, 629, 630  Next
DenverB
DenverB is offline
PostPosted: Wed Nov 19, 2014 7:15 am    Post subject: Reply with quote
Yes, the back seat/bed has been removed in this photo - I mentioned the other day (in a post about four above this one) that I had it out for cleaning as well as some interior refurb, hence the shot of the inside. I'll get some photos of the van up in the next day or so. Very Happy
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com
Team WorldTour
Team WorldTour is offline
PostPosted: Thu Nov 20, 2014 6:20 am    Post subject: Reply with quote
I just swapped out all (except indicators) of my outside lights with LEDS from Campervan Culture.
Also, I changed out my nasty-ass air baffles for the nice GW pieces (Part #: RAD-BAFFLE-SET).
While I had the grille off, I found the wires to the front fog lights! Now I just need for TUV to approve the Terrapod lights!!!
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
termuehlen Premium Member
termuehlen is offline
PostPosted: Thu Nov 20, 2014 6:20 pm    Post subject: Instrument lights Reply with quote
Since its getting cooler, I have started to switch the fresh air control levers to get a little heat. When I tried in the evening, I was fumbling in the dark to find the control levers. I realized that many of my interior instrument light bulbs were not functioning. I ended up replacing light bulbs behind the fresh air control levers, the automatic transmission console and the original cigarette lighter.
In my van, the following switches should all be illuminated when functioning properly:
Speedometer
Tachometer
Clock / warning light cluster
Electric window switches
Cigarette lighter
Emergency flasher switch
Rear window defroster switch
Fresh air control levers
Heater fan switch
Automatic transmission console
Much better now...
1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx
bosruten
bosruten is offline
PostPosted: Fri Nov 21, 2014 7:07 pm    Post subject: Reply with quote
I replaced the hatch struts, added a screen for the slider door window and went to apply the 3M plastic covers for the headlights...but it's too cold, I don't think they will stick. I'm still working on my heated seats, hopefully they'll be all wired up this weekend.
'87 Syncro Weekender
Jon_slider
Jon_slider is offline
PostPosted: Fri Nov 21, 2014 8:14 pm    Post subject: Reply with quote
got the Airtronics aka Espar, aka Eberspacher D2 diesel furnace serviced with new glow plug screen and new fuel filter screen. Yes! it works
replaced belt tensioner on Tdi motor, one less clack clack noise
raised Injection Quantity from 3 to 5, thanks to a savvy friend with vag com, not hammer mod, now smoother throttle response and better highway acceleration when passing
next up, reboot a rear axle currently removed, temporarily running on a $90 Autozone axle, no problems in general pavement use so far, knock wood
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
midmo81
midmo81 is offline
PostPosted: Sat Nov 22, 2014 3:02 pm    Post subject: Reply with quote
Followed other Samba reports and installed 3 inch bilge blower fan in heat tube. Had to do it the hard way though. Confused Tried behind front grill first, but fan noise was excessive. Moved to the back about even with propane tanks and sound is much less. Already had the silver insulation around the stock tube from last year - no help - so just cut in and added fan. It is 50 degrees out today, but last week it was cold and wished I had done this sooner. Plenty of heat back there, just need to get it up front.
1981 AC Westy
dhaavers
dhaavers is offline
PostPosted: Sat Nov 22, 2014 4:41 pm    Post subject: Reply with quote
Last trip to town, wash/wax, topped off gas & stabilizer, oil/filter change, put on battery maintainer & tucked away for winter.
Sleep, my pretty... <sigh>
"The WonderVan"
oldhuldy67
oldhuldy67 is offline
PostPosted: Sun Nov 23, 2014 12:14 pm    Post subject: PopTop Adjust-O-Matic Reply with quote
OK, I know it's not a novel or even new idea..but, it was for me. I needed a little headroom for short stops or "pre-stealth setup."
Now, off for the Blue Ridge.. Much to be thankful for
pbrown
pbrown is offline
PostPosted: Sun Nov 23, 2014 5:21 pm    Post subject: Reply with quote
I installed my new MB CLK 320 wheels with BFG 215-70-16 tires. Looks great.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
Team WorldTour
PostPosted: Mon Nov 24, 2014 2:33 am    Post subject: Re: PopTop Adjust-O-Matic Reply with quote
Never thought of that...
We used the prop-rod from our GW rain fly!
Click to view image
Welldon82
Welldon82 is offline
PostPosted: Mon Nov 24, 2014 1:01 pm    Post subject: Reply with quote
Decided to take a break from the hard stuff and do something a little easier.
Scraped and sanded clamshell to prep for new undercoat:
Also upgraded the new calipers:
I guess you could say...I bleed brakes...YEEEEAAAAHHHH!
oldhuldy67
PostPosted: Tue Nov 25, 2014 7:32 pm    Post subject: Re: PopTop Adjust-O-Matic Reply with quote
Hey, Grus Gott aus Stuttguart! I had 6 very happy years there courtesy of the 84th USArmy band in Esslingen, am Fielder stat? Kelly Barracks. My Deutsch is ganz schleck! Had a 78 Bay window Westy. What fun. Anyway, I have a pop top "lift kit"...whoosh! So, Up it goes. I also have a GW rain fly prop rod that needs to be repurposed. Any ideas?
DenverB
DenverB is offline
PostPosted: Tue Nov 25, 2014 9:36 pm    Post subject: Reply with quote
- Put new latch on the rear bed seat so that it properly pulls forward/lays down into a bed (simple job, but a walkthrough to come later this week)
- Cleaned out the storage bin under the seat.
- Pulled apart the stainless stove unit to clean out remaining grease.
- Cleaned out exposed metal detail areas under tent windows when the top is popped.
- cleaned vinyl panels to prep for dyeing
- decided that I'm going to cover the bumpers and about 6-8 inches up from the rockers sprayed with LINE-X so I can stop caring about rock chips and small bumper chips.
heart4Pahoa
heart4Pahoa is offline
PostPosted: Fri Nov 28, 2014 1:17 pm    Post subject: Reply with quote
Finally got around to installing 3 point rear passenger side seatbelt for our daughter who is about to exceed her rating for the car seat she is in. It will now be user by her little brother. Simple install, but makes the Mrs. and me feel better knowing she is a little safer.
nacradriver
nacradriver is offline
PostPosted: Mon Dec 01, 2014 1:19 pm    Post subject: Reply with quote
Love these long weekends... gives me a chance to get stuff done..
Installed the Vanistan Oil Cooler that has been sitting on my workbench since September, changed the oil, and put in new spark plugs... then took her for a good 100 mile freeway run...
The oil cooler is awesome... kept the temp just a hair over 180 degrees on the VDO Oil Temp gauge.. New plugs helped too!
Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
KevinsKamper
KevinsKamper is offline
PostPosted: Wed Dec 03, 2014 2:00 pm    Post subject: Reply with quote
Totally rebuilt the "Water Dept" on my newly acquired 1990 Westy today....neither the tank pump or the water level sensor worked , the water lines were disgustingly black inside and it still had the original faucet......so I ripped out all the existing parts and replaced it all.
New Shur Flo faucet
New water pump and clear water lines.
New level sensor.
New fill hose to the tank.
So now I'm ready for warmer weather to check it for leaks.......so next project up?.....replace fuel lines, coolant hoses, wheels and tires, etc,etc,etc........
BillWYellowstone
BillWYellowstone is offline
PostPosted: Fri Dec 05, 2014 4:31 pm    Post subject: Reply with quote
Got a set of used alloys and new Goodrich tires. Stayed 14" don't want to do the lift. The shifter mechanism adjusted so that I can or better yet, my wife can easily find first gear!
Talked with mechanic about overall health of the engine, it is getting a little tired. Some blowby on 2 cyl, pushes dip stick up enough to push some oil out.
Looking over the next year or so for a good rebuilt to swap in. Can't really afford a Subie conversion, but maybe if I keep putting some money away I will have enough when it is inevitable.
Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round.
nacradriver
PostPosted: Sat Dec 06, 2014 5:43 pm    Post subject: Reply with quote
Today, went through the engine bay and cleaned all the grounds again, this time with a Dremel to get them good a shinny...
Put on a new rotor and cap and new plug wires....
Took her for another good run.... and she likes all the new stuff....
vanis13
vanis13 is offline
PostPosted: Sat Dec 06, 2014 7:24 pm    Post subject: $3 VSS – speed sensor - cruise – Subaru Reply with quote
bolt head passes under sensor and generates a speed signal
Full writeup here - http://www.thesamba.com/vw/forum/viewtopic.php?p=7471505#7471505
LJ12A3-4-Z/BX Inductive Proximity Sensor Switch NPN DC6-36V
Ebay search – http://www.ebay.com/sch/i.html?_from=R40%7CR40&...PrefLoc=98
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sun Dec 07, 2014 1:04 pm    Post subject: Reply with quote
In my bid to earn the Ex Lax smooth move of the year award...
Yesterday I decided to remove my perfectly operating but slightly internally damp LS Euro 7" Hella headlight. These are the OE kind with the install tabs welded to the housing, so there's no chrome ring. Anyhoo, I get the bright idea to fill the light with water, to see where it's leaking...sounds legit, right? I fill it up to the city light hole, and then raise it up to see, but when I remove my hand from the lens, it pops right off and shatters in the bottom of the sink. You'll be proud to note that I just quietly stared at the mess and didn't resort to name-calling or beating my kids. FML
Does anyone have a cheap single Euro Hella light or just the lens? Since I don't have any chrome rings around, I'm kinda stuck using a sealed beam duct-taped in place in the mean time. FML
Casey--
'01 Weekender --> full camper
y u rune klassik?
Page 377 of 630
