?Waldo? Samba Member
Posted: Fri Nov 21, 2014 12:00 am Post subject: |
I can't seem to find where AA Transaxle recommends MT90 even for break in. Got a link? |
insyncro Banned
Posted: Fri Nov 21, 2014 4:56 am Post subject: |
Never underestimate the amount of hear say and misinformation that you can find on the internet, from "know it all" types who only cut and paste out of context.
All of the definitive statements being made here are very entertaining. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Fri Nov 21, 2014 6:46 am Post subject: |
Andrew A. Libby wrote: |
Andrew, I looked on the aa transaxle website and cannot find the Redline MT-90 recommendation for break in. But I know it was there at some point in the last year or so. I'm on my third aa tranny and am/was familiar with their break-in recommendations, which now seem to have changed. _________________ Dave O
The Western Syncro build
Posted: Fri Nov 21, 2014 7:15 am Post subject: |
I have no doubt that they recommended MT90 in various ways in the past but SD seemed to think the discussion was about TODAY, even to the point of adding the snarky and condescending 'Understand?"...
syncrodoka wrote: |
They no longer recommend it as gear oil and haven't for a while.
From earlier today.
Jon_slider wrote: |
making the issue even more confusing, is that both GW and AATrans now recommend Redline |
Understand? |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Fri Nov 21, 2014 7:52 am Post subject: |
Their break in procedure isn't online. They sent a slip with instructions and i called to confirm that they is their current recommendations. If you want to argue with someone give them a call.
I could care less about arguing a point with you or someone that has many documented issues with trannys that tries to put opinions into facts.
Have fun.
insyncro Banned
Posted: Fri Nov 21, 2014 8:11 am Post subject: |
syncrodoka wrote: |
I could care less about arguing a point with someone that has many documented issues with engines and trannys that tries to put opinions into facts. |
Agreed.
When it comes to engine conversions, transmissions and CVs, this particular poster is not accurate on a regular basis.
Read his signature, that sums it up.
"A little nudeness and disrespect can elevate a meaningless interaction to a battle of pricks and add drama to an otherwise dull day."
Save the drama for yo Mama Dude
The only place Redline MT90 is used at my shop is in the waste oil furnace we just installed |
Posted: Fri Nov 21, 2014 9:12 am Post subject: |
I didn't get a break-in slip when I had my trans rebuilt by AA. It must have been before they started that practice. They do have their warranty online and it says absolutely nothing about MT90 for break-in or for long-term use. At least, not TODAY.
As far as anyone's particular brand of irritating (obnoxious, condescending, arrogant, argumentative, entitled, braggadocio, snarky, belittling, insulting, etc, etc...) comment being better than anyone else's, I'll quote Fat Ba$tard, "Oooo, everyone likes their own brand, don't they? This is magic." |
Jon_slider Samba Member
Posted: Fri Nov 21, 2014 10:19 am Post subject: |
syncrodoka wrote: |
I could care less about arguing a point with you or someone that has many documented issues with trannys that tries to put opinions into facts. |
actually, I try to put facts into my opinions
for example, my first 3 tranny builds in my 87 TDi syncro had reused cases, they all popped out of granny or reverse when using engine braking. No matter WHAT gear oil I used.
My 4th tranny build had NEW cases, and was solid as a rock. Operator error, after 5000 miles, cracked the mainbearing housing. My 5th tranny, again new cases, has been solid for the past 10000 miles, and counting.
In my 2.2 Subaru powered 86 Syncro, when I was coincidentally using Redline, my 3-4 slider failed. That was not caused by Redline, the failure is common, regardless of lubricant.
However, it is NOT opinion, to state that Redline is a GL4 that the manufacturer states is NOT for transaxles with Limited Slip, or hypoid gears.
Sorry you feel my opinion lacks factual support. I do my best to be honest, accurate, and to quote supporting info from confirming sources.
But clearly, many people think I state my opinions as facts. Fact is, theyre my opinions , plus other peoples facts to back them up.
Rock on with the Redline
Whatever gear oil you choose, if considering a rebuild, I highly recommend new cases. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
flomulgator Samba Member
Joined: March 07, 2013 Posts: 950 Location: Leavenworth, WA
Posted: Fri Nov 21, 2014 10:33 am Post subject: |
I can't believe no one's noticed this:
"A little nudeness.... can..... add drama to an otherwise dull day."
I completely agree Jon! _________________ She's built like a steakhouse, but she handles like a bistro! |
Posted: Fri Nov 21, 2014 10:50 am Post subject: |
flomulgator wrote: |
I completely agree Jon! |
Thanks, now I know somebody is paying attention.. LOL
Just my opinion of course _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
insyncro Banned
Posted: Fri Nov 21, 2014 11:29 am Post subject: |
So if you are nude and used Redline MT90 in your $yncro transmission, all will be OK?
I could see cold shifting being easier due to shrinkage, not the fluid. |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Fri Nov 21, 2014 8:02 pm Post subject: |
I just realized that oil is a bit like religion. A lot of faith is required when you choose a brand of lubricant because those moving parts are hidden from view, you have to trust the oil will be their savior. Naturally, once you put your faith in a brand you become passionate about it and dismissive of others.
I would submit that most of the good/bad qualities about oil expressed here are based mainly on faith. Unless you run two exact transmissions under exactly the same conditions, each with two brands of oil, you can't say that one is better than the other, and more importantly, how much better. I understand there is good solid research that goes into oil science, but I haven't seen very much of that quoted here. I will say that Gears seems to know what he is talking about, but can he even say that using oil A will result in X% more wear over using oil B? From reading this thread, I'm convinced that Redline may not be the ideal oil for a Vanagon Transmission, but is it really going to be the cause of an early failure? If so, can anyone say with certainty, how much early? What I'm saying is that this whole discussion, may be splitting hairs--but I'm probably wrong. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri Nov 21, 2014 8:19 pm Post subject: |
In my business (well .. I'm retired, but my old business) gears lasted 30 hours on average. We got to see first hand which oils (and oil types) allowed gears to last 40 hours vs 15-20 hours. Most of our races averaged 4-5 hours, but for a 24-hour race, oil choice was pretty darn important .. especially on gears that had already been run in qualifying or in a previous event.
Most street car guys change their oil and to them, if shifts seem smoother, they figure "this is better oil !" .. but I look at oil performance in a different way. When the transaxle is disassembled, the parts are either in good shape, or they require replacement. Synchronizers are cheap. Bearings are cheap. R&Ps are not. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Fri Nov 21, 2014 8:40 pm Post subject: |
gears wrote: |
Most street car guys change their oil and to them, if shifts seem smoother, they figure "this is better oil !" .. but I look at oil performance in a different way. When the transaxle is disassembled, the parts are either in good shape, or they require replacement. Synchronizers are cheap. Bearings are cheap. R&Ps are not. |
So....... What oil do you recommend for us street drivin' Vanagon folk (with 1.8Ts )??? _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
4x4BNB Samba Member
Posted: Wed Dec 03, 2014 12:03 pm Post subject: |
Free shipping is only over $100. Better get two bottles... |
mtwesty84 Samba Member
Posted: Wed Dec 03, 2014 12:13 pm Post subject: |
Prior to Daryl at AA passing away I spoke to him at length on this for my 2WD van. If you are under 165 HP any 75W90 tranny fluid will do. He said that Redline changed their formula and he would not use it anymore. Just his opinion and Just my .02 |
Posted: Wed Dec 03, 2014 12:18 pm Post subject: |
here is the lowest price Swepco Ive found, its 201, which imo is sufficient, 210 is not needed..
http://www.rrproducts.com/p-759524-swepco-201-gear-lube-iso-460-1-gal.aspx
and here is another source Ive used
http://www.paragon-products.com/SearchResults.asp?Search=swepco&Search.x=0&Search.y=0
lots of discussion of the various Swepcos in this thread.. read posts by gears, hes the expert
http://www.thesamba.com/vw/forum/viewtopic.php?t=546909&start=0
Regarding fill volumes, a Syncro Tranny holds 4.2 quarts, the front diff holds 1.6 quarts
So a 1 gallon bottle of Swepco is probably sufficient for a refill, since trannies dont usually drain completely dry. But if you plan to do the front diff, 2 gallons will be the minimum purchase, afaik Swepco does not come in smaller than 1 gallon units. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
