termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Tue Nov 18, 2014 2:11 pm Post subject: Unidentified electrical connector |
Can anyone identify this electrical connector for me? It is located behind the dash between the radio and the instrument cluster of my 1988 Westfalia (automatic). I just put a new stereo in with a switched power source and am currently using the positive wire from this connector for my stereo.
It is a five pin connector with three wires. They are a Black, a Brown and a Gray/White. (The red wire is my own radio connection.) Now that I am using this source of power, I am wondering if it is OK. I pulled the radio/clock/etc fuse and it did not cut power to this supply. I looked through the Bentley manual and do not see this connector (I am sure I missed it in there somewhere). It is likely something that was either abandoned with the Subaru conversion to my van or it is an accessory that my van does not have.
Any help is appreciated. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Tue Nov 18, 2014 4:54 pm Post subject: |
You should not use that plug at all. Unplug your stereo from it and leave it alone.
Mark |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
GreenMachineVW Samba Member
Posted: Tue Nov 18, 2014 6:56 pm Post subject: |
That is part number 171941599. Here is another thread on it. I did get one Vanagon harness that had that connector as well. Indeed, there is google reference to it as a diagnostic flat connector.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7426093 |
Posted: Tue Nov 18, 2014 7:10 pm Post subject: |
Whoa! Thanks everyone. As always, you have assembled a wealth of great information here. _________________ 1988 Westfalia automatic Subaru OBD1
chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Tue Nov 18, 2014 11:22 pm Post subject: |
ok, how about this connector? found it behind my radio. it is not currently connected to anything on the other side.
_________________ '74 transporter panel
'91 vanagon carat NAHT |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Posted: Wed Nov 19, 2014 11:26 am Post subject: |
That is for connecting the oscillation over thruster. I wouldn't use it, since two wires have been cut; you may materialize inside a mountain.
_________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
?Waldo? Samba Member
Posted: Wed Nov 19, 2014 11:44 am Post subject: |
Corwyn wrote: |
you may materialize inside a mountain. |
That would only be an issue if your phase shifter wasn't wired in right.
Posted: Thu Nov 20, 2014 12:43 pm Post subject: |
Image may have been reduced in size. Click image to view fullscreen. |
That connector appears to be documented in my Bentley manual as Terminal T3c on the "main wiring diagram - interior lights" for 1988, 1989 (Page 97.128 in my manual). The wiring which has been cut on your connector was attached to the cigarette lighter and the Radio wiring.
Unfortunately I can't tell you what it was connected to. Maybe it was for some kind of factory radio accessory. _________________ 1988 Westfalia automatic Subaru OBD1
Posted: Thu Nov 20, 2014 5:48 pm Post subject: |
This should be it. 3 pin connector T3 with White/Blue, (2)Brown & (2)Red wire connections. Apparently it was used to control an "Amplified Speaker", if your van came with that option.
chachi Samba Member
Posted: Fri Nov 21, 2014 10:12 am Post subject: |
oh yeah that is totally it. now i just have to figure out what an "amplified speaker" is... but good to know it's not critical.
thanks for the bentley digging! _________________ '74 transporter panel
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Fri Nov 21, 2014 11:30 am Post subject: |
chachi wrote: |
thanks for the bentley digging! |
Do you have a Carat or Blue/White star? Might be for the "Bass Reflex Speaker" in the panel behind the driver's seat. I guessed it was for an optional powered antenna but good to know what it's really for!
_________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
chachi Samba Member
Posted: Sat Nov 22, 2014 12:17 am Post subject: |
i think it's just a regular old GL but i've never pulled that panel so who knows...? _________________ '74 transporter panel
