leszer Samba Member
Joined: February 13, 2014 Posts: 12 Location: Kentucky
Posted: Sun Nov 23, 2014 5:41 pm Post subject: 74 Beetle Blinkers, cautions work - tail lights do not |
The previous owner of my bug mangled the electric and I'm trying to sort it out.
Most of my lights work except my parking/tail lights and my reverse lights. I was wondering if someone could explain the wiring behind them?
I tried to figure it out from the wiring diagrams but I'm just not grasping it.
I mean I am completely clueless and the wiring is torched or I'd take pictures. There is no wire going to the light switch. Everything I've seen says the tail lights/parking lights go in connector 58 but where does it go on the fuse panel?
I have several wires connected at fuse 1/2 where it looks like the wiring diagrams say the parking/tail lights are but no power to those fuses, figured it would get this from the light switch power?
Any help appreciated. |
Her74buggy Samba Member
Joined: September 29, 2013 Posts: 367 Location: Houston
Posted: Sun Nov 23, 2014 10:17 pm Post subject: |
Did you check the inline fuse in your engine bay for the reverse lights? |
leszer Samba Member
Posted: Mon Nov 24, 2014 6:51 am Post subject: |
No, wasn't aware of one. Where is that located? I ask that but I'm also going to google right now. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Nov 24, 2014 8:42 am Post subject: |
Speedy Jim's site has many useful diagrams. Here is his diagram for tail lights:
At the fuse box, find the single grey wire that runs from the fuse box to the headlight switch #58 terminal. Use this '72 wiring diagram. It is easier for most to understand:
Notice how the grey wire connects to either fuse #1 or #2 but the black "bridge" connects that input side together. This allows the wire from the headlight switch to power BOTH fuses. This is a key point. If you connect this headlight switch wire to the wrong side the current will not flow through the fuses correctly.
On the opposite side of the #1 & #2 fuses you will find many grey and grey-striped wires. The grey/black and grey/red wires run to the rear of the car. Grey/red is to the right side. Grey/black is to the left.
Test the single grey wire from the headlight switch while the headlight switch is in the 1st position (parking lights). You should get a voltage reading. If so, test the opposite side of the fuses and make sure you are getting the same reading.
Work your way to the rear of the car and make sure you have voltage readings at each junction along the way. The junctions at the rear are tucked behind the tar paper on either side of the engine compartment. _________________ AshMan40
