J. Matt Royston Samba Member
Joined: November 26, 2009 Posts: 94 Location: Roseburg Oregon
Posted: Fri Jan 10, 2014 5:01 pm Post subject: Seat Heaters |
Anyone put electric seat heaters in your Bay? If so do you have pictures of where you put the control switches?
I want it to look as stock as possible.
Thanks
Matt |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Fri Jan 10, 2014 5:14 pm Post subject: |
Randy in Maine did, hit him up. He'll probably see this soon enough anyway _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Opossum Samba Member
Joined: February 26, 2005 Posts: 735 Location: Islets of Langerhans
Posted: Fri Jan 10, 2014 5:57 pm Post subject: Re: Seat Heaters |
J. Matt Royston wrote: |
Thanks
Matt |
I put mine just below the seat. I think there was a small hole there already. There is a switch in the same location on the passenger seat.
_________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
Posted: Fri Jan 10, 2014 10:27 pm Post subject: Re: Seat Heaters |
Opossum wrote: |
Thanks
Matt |
Thanks, I cant quite make out the exact location, can you take a pic from a little farther back?
Thanks
Matt |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Jan 10, 2014 10:47 pm Post subject: Re: Seat Heaters |
Opossum wrote: |
Thanks
Matt |
Like _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Sat Jan 11, 2014 7:31 am Post subject: Re: Seat Heaters |
Thanks
Matt |
That is the right front of the driver seat. The steering wheel would be at the top of the pic. That button would be below your right knee. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Sat Jan 11, 2014 10:48 am Post subject: |
Ooooo heated seats.... I was just think about this, looking up kits on eBay. Are there and pics of the install? _________________ 69 Westy |
hagermanfolley Samba Member
Joined: August 03, 2005 Posts: 235 Location: Boise, ID
Posted: Sat Jan 11, 2014 3:00 pm Post subject: |
Yes pics please. _________________ 1970 Westy |
chabanais Samba Member
Randy in Maine Samba Member
Posted: Sat Jan 11, 2014 4:18 pm Post subject: |
These are the ones that I have. His and hers. Switches go in the pedestals.
http://www.heatedseatkits.com/heatedseatkits/iheat2/index.html
They require up to 10 amps of juice each. I have a 70 amp alternator and camping battery. They are wired off the camping battery. |
northernbus77 Samba Member
Posted: Sat Jan 11, 2014 4:47 pm Post subject: |
This is something I have wanted to do for a while now myself. I also have a couple questions.
I have a set of heated seat elements from a '04 Chev. Impala I got from the local junkyard. My questions are;
1. How do I determine the amp draw of these units?
2. What is the limit my 35 amp generator in my '71 can handle? |
Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Sat Jan 11, 2014 7:18 pm Post subject: |
Yes, heated seats in an aircooled VDub are the cat's pajamas... heated pajamas at that. The version I use generates heat in 1-2 minutes... way quicker than the heated seats in my Jetta(s).
Mine are controlled by a couple of aftermarket plunger-type switches in the dash (one for each side) and I used two-terminal plugs:
http://www.princessauto.com/pal/Connectors-adapters/2-Way-12-in-Trailer-Harness/8198137.p
so that I can unplug the seats and remove them during the summer.
I upgraded to an alternator so can't comment on the power draw, other than to say the seats I sourced came with very tiny wires... I bet they only draw in the order of 5 amps or so. _________________ Vince Waldon Edmonton Alberta CANADA
1970 baywindow |
Posted: Sat Jan 11, 2014 11:00 pm Post subject: Seat Heater Switch location |
Thanks everyone! I can see in the picture that those switches were in a walk thru, My double cab is a bench and the pedestal is way different so we chose to go in the dash and lengthen the wire looms to accommodate. We aren't done yet but here are a couple pics.
Matt |
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Thu Jan 16, 2014 1:47 pm Post subject: Re: Seat Heaters |
Opossum wrote: |
Thanks
Matt |
Did you have to do anything to the hole? I can't get my switch in and its the same as yours. Maybe I need more muscle powah. _________________ '71 Westfalia |
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Nov 24, 2014 8:16 am Post subject: |
I installed the seat heater pads in my seats several months ago when I rebuilt them with new pads but only got around to wiring in the switch this past weekend. I bought one of the Install Bay kits that does the bottoms and backs for two seats, but also got the single 5-position switch that controls both seats (which makes it a bit more difficult to find a good mounting point). I ended up just mounting it on the side of the passenger seat stand...which makes it extend into the walkthrough "hallway" a bit...I temporarily installed it with two zip ties pending a better location.
I have a '75 and ended up jumping off the 16A circuit for the wiper motor and rear window defroster (which I've never used)...#10 if I remember correctly...then going into an auxiliary fuse block. So far so good! _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
raygreenwood Samba Member
Posted: Mon Nov 24, 2014 9:11 am Post subject: |
Just a couple of points...and I realize that having any heated seats in an ACVW is a huge bonus to start with.
If you are getting seat heaters out of the junkyard....get the newest ones you can and check on reviews of how well those heaters worked.
I work within the industry that makes most seat heater grids and window and mirror defroster grids.
The technology in the past 5-7 years has improved by orders of magnitude in heater grid quality, current draw, lifespan and control ability.
Don't do major mods on your seats for 10 year old heater grids
I have driven a lot of cars with heated seats and they are nowhere near equal. Much of it is in the design of the grid and the location of the pad within specific heats....but also has to do with quality of controls.
Many seat heaters are not very incremental. They either get too hot too fast...causing you to be constantly cycling them....or they do not heat very well or are very slow to heat up.
If you can find them...seat heaters from water cooled VW's from about 2011 on up are just plain awesome. The ones in my 2012 golf get significantly warm on high setting in less than a minute. They have three positions....you start them on three and your backside will be frying in the coldest weather in less than five minutes...then crank it down to 2 or 1 to maintain heat.
They also heat your back...not just the seat base pad.
A lot of the aftermarket heater kits have poor controls. Just off/on for many, not enough watts for others, poor construction for others.
From the looks of those in the pictures you probably have HSK....which are some of the better technology out there in aftermarket
http://www.heatedseatkits.com/heatedseatkits/index.html
Get the waterproof ones...trust me.
This company...Rostra Precision controls....
http://www.rostra.com/comfortheat-automotive-seat-heater-by-rostra.php
Most probably manufactures the kits for HSK....and I have made parts for Rostra (mostly mirror heating elements under contract)....and Rostra has a much better array of switches and controls available.
This company....does not have as much info on controls...but their knowledge of the differences in the parts (resistive wire versus resistive wire with membrane joiners for the pads)....exhibits experience at least in the mfg end.
As with everything else in acvw...do your homework and you will succeed. Ray |
DougB Samba Member
Posted: Mon Nov 24, 2014 10:41 am Post subject: |
All good points! It never even occurred to me to reuse heater elements and/or controls from an existing car.
Here's the kit I bought (though I paid nowhere near what this kit is advertised for...not sure why the high price):
http://www.amazon.com/Driver-Passenger-Illuminated...l+bay+ibh3
The switches have off, plus 1 - 5...but there is a half increment in between each number, so the dials effectively have like 10 positions.
Admittedly this rectangular control makes it more difficult to find a good mounting point on the Bus, and is more the import car standard size for switch cutouts in the dash. You can't just drill a big hole and put in some circular switch like in the other pictures. I like the temporary location I found but wonder if I'll want to reposition it over time. I'll post a picture when I have a chance. _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Posted: Mon Nov 24, 2014 11:07 am Post subject: |
DougB wrote: |
Admittedly this rectangular control makes it more difficult to find a good mounting point on the Bus, and is more the import car standard size for switch cutouts in the dash. You can't just drill a big hole and put in some circular switch like in the other pictures. I like the temporary location I found but wonder if I'll want to reposition it over time. I'll post a picture when I have a chance. |
That looks like one of the Rostra mfg kits. I forgot to post the link to the third company in my last post.....but that cost you list in the amazon link.....is not really high at all if the parts you are getting ard genuine parts made by a company with good production practices. ...and not a 3rd world knock off.
The larger costs in the products are the switch and control mechanisms and in the encapsulation of the actual seat heater grid. The cheaper ones are just wire. The more expensive ones have silver printed membrane switch connections....which usually implies multiple heater grids...bottom and back. Expensive to make. Ray |
