pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Tue Nov 25, 2014 8:27 pm Post subject: Sliding Window Silicone Removal |
I need to dismantle a pair of sliding windows. I understand that the aluminum frame is held together with silicone adhesive. Does anyone have any tips for removing the silicone or whatever it is? The sliders are camper versions in case it matters.
I'm planning to powder coat the frames black.
Thanks, _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Tue Nov 25, 2014 9:27 pm Post subject: |
Your local hardware store will have silicon remover fluid that functions like paint remover. i recall there is a thread that demonstrates how to pull the unglued frame apart.
i pulled one of my sliders apart and never used it. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Tue Nov 25, 2014 10:49 pm Post subject: |
Do you know that you do not have to "dismantle" the window frame to get the sliding window out? You just flex the frame open to get the slider out.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7342046&highlight=#7342046
When I did my camper sliding windows the,rubber seal and rubber bumper, was hard to get. The fuzz seal you can get at Ace Hardware.
And yes I did want to black out my camper sliding window too. Ran out of time for the painter. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 925 Location: Calgary, Canada
Posted: Wed Nov 26, 2014 3:14 pm Post subject: |
But if you do want to dismantle the window, here is a description with photos.
http://www.griffco.ca/interest/vw/slider.htm _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
pbrown Samba Member
Posted: Sat Nov 29, 2014 5:18 pm Post subject: |
I have both window assemblies completely dismantled. That was a fun little project. I found a spay bottle of unknown chemicals that stated to disolve silicone. It seemed to work well.
My plan was to powder coat all the aluminum parts. I'm having second thoughts and may send the parts off to Apex to be black anodized. The fixed piece of glass is such a tight fit that I'm afraid that the thickness of the coating will make reassembly difficult. _________________ Patrick Brown
